Lower?
Old Sep 16, 2004 | 07:52 PM
Nates99ss's Avatar
Nates99ss
Default Lower?
Ok, I just want y'alls opinnions, and then also some info. Im going to post a pic to show you how my car sits now. I personally want it to be lower in the front, and a lil in the back. Just post up comments, and also any links to how to lower the car.
Old Sep 16, 2004 | 07:57 PM
USARMYTTT's Avatar
USARMYTTT
Nice car, the rear looks fine but I would take the front down a little further.
Old Sep 16, 2004 | 08:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It looks like you've lowered it within the stock bolt adjustment range already?
If yes, you'll need to cut the front bushings in the front to get it lower. The how-to can be found here:
https://www.corvetteforum.com/techti...D=90&TopicID=1
For the back (again, assuming you've already loosened the nuts as much as possible), I'd recommend getting longer grade 8 bolts....1/2" x 6.5" should suffice. No need to cut the rear bushings.
Old Sep 16, 2004 | 08:09 PM
Nates99ss's Avatar
Nates99ss
Well...the plans for the car include some new chrome 18x12 Z06 wheels, and then 18x9.5's up front. I want the rear to look nice and slammed with those wheels on, and Ive always thought the front needed to be lowered some anyways. Im not sure how low it is as of now, and not sure how it was done, bought the car from a guy, he didnt say. Anyways, thanks for the comments guys!
Old Sep 16, 2004 | 08:16 PM
HP-JNKIE's Avatar
HP-JNKIE
Always go lower......
J
Old Sep 16, 2004 | 08:23 PM
Nates99ss's Avatar
Nates99ss
J
My thoughts exactly!
The only problem is Texas roads, or atleast around here, SUCK for lowered cars!
Old Sep 16, 2004 | 09:13 PM
GR8-LIFE's Avatar
GR8-LIFE
Here's my .02. I have read where members went back to original height after lowering as far as the stock bolts would take. Before you start cutting front bushings, drive around the way your car is now for awhile and take note to the small inconveniences of lowered cars (servicing them, pavement contact depending on where you live, shock adjustemnts etc)
If you can find people who can service cars lower than what your car is now (or if you do it yourself ) and you endure other little issues, then go for it.
Old Sep 17, 2004 | 02:02 AM
Nates99ss's Avatar
Nates99ss
I like that...lower it as low as I want, and just try out the ride for a while, and see if I can stand it or not.
Old Sep 17, 2004 | 08:47 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Lower!!!!! Get some Bilstein Shocks. You'll love it!!!!
Cut front bushings & longer Rear bolts.
Old Sep 17, 2004 | 10:55 AM
MSGvette's Avatar
MSGvette
Wish I could go lower but roads here suck.
Old Sep 17, 2004 | 12:54 PM
dmoran1845's Avatar
dmoran1845
Looks great.
Old Sep 17, 2004 | 03:36 PM
TIKTGTR's Avatar
TIKTGTR
Car really looks great Yes, it does need to be lower int the front. My 99 wouldn't get low enough for me on stock bolts so I removed my front bolts and shaved 1/3 off the rear Car rides just fine and has been for almost a year now
Old Sep 17, 2004 | 03:48 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I think the car looks perfect the way it is. I wouldn't bother with the front.
Old Sep 17, 2004 | 03:52 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
If that were my car, I think I'd leave the front as is and raise the rear a little.
Old Sep 17, 2004 | 05:45 PM
Nates99ss's Avatar
Nates99ss
DAYYYYYUUM TKTGTR as Ive told you before, incredible looking car! I sent you a PM asking you how you lowered it, but I deleted it before I got my car. I really like how your sits, I want mine somewhere around there!
To Lower?
