[Z06] ZO6 vs C5 air intake
There are usually arguments on both sides that you will get some results, probably better throttle response, but not enough for SOP feel. Sometimes gains are negated as the computer "learns" the new air flow and tuning may be required to get the most out of such mods (but that can be said in general for most mods). There is a balance that needs to be arrived out between intake and exhaust as well, so on and on the mods generally go ...
If all you want to do is make an improvement, it surely would help. If what you want to do is mod the c5 to become like a Z, it's going to take quite a bit of modding and $$$ and you still will not get the handling and agility of the Z.
PS ... I guess you were only asking about the differences between just the intakes, so my apologies on the long winded response. The majority of responses you are likely to get would be the aftermarket intakes as long as you want to change it ... If interested, here is alot of good info about the Z ... http://www.z06vette.com/01.php
"will it make much difference?"
--- I doubt it. On the intake side, you would do better by going with a kit from blackwing or halltech.
dave
What I was alluding to was that on a car with a more restrictive airflow for starters (Standard C5) the air box swap with an aftermarket one along with opening the area around the fog lights, a low restrictive air bridge and throttle body coolant bypass and some tuning, it could be possible with the ram air effect. I also did say that would probably be the max if lucky. That certainly would not happen just by putting a Z air box alone of course.
