Rotor bracket question.
Old Sep 17, 2004 | 05:30 PM
Wildcat99's Avatar
Wildcat99
Default Rotor bracket question.
does anyone know the size of the bolts that hold on the rotor bracket? Getting ready to do some changing and need the size. Thanks in advance.
Old Sep 17, 2004 | 05:48 PM
mdbennes's Avatar
mdbennes
I did it yesterday and want to say it was a 13/16 socket...you might need a breaker bar or air impact wrench...mine were on super damn tight
Old Sep 17, 2004 | 06:06 PM
boatboatboat's Avatar
boatboatboat
Be careful, I snapped a bolt off 2 weeks ago. Those MO FO's are tight.
Old Sep 17, 2004 | 10:55 PM
BHP's Avatar
BHP
They are loctited on. Heat them up before removing.
Old Sep 18, 2004 | 02:00 AM
VlackBette's Avatar
VlackBette
Stupid question, but what'd you use to heat them up?
Old Sep 18, 2004 | 02:06 AM
Richin Chicago's Avatar
Richin Chicago
They are 21mm. When you replace them torque them to 125 ft lbs.
Old Sep 18, 2004 | 03:08 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I know that the bolt that hold the rotor to the braket are 15mm and 18mm
Old Sep 18, 2004 | 10:05 AM
Richin Chicago
I'll just do the whole list.
Wrenches required for brake and rotor job.
Rotor bracket: bolts 21mm socket with breaker bar
Caliper bolts: 15mm closed end box wrench
Caliper pin nuts rear brakes : 16mm (open end)
Caliper pin nuts front brakes : 18mm (open end)*
*on 2000 and earlier all caliper pin nuts were 16mm
Torque required for install is 125 ft lbs for the 21mm bracket bolts and 23 ft lbs for the 15mm caliper bolts.
Lift the car as high as you can get it for more leverage on the 21mm bracket bolt. Also turn the front wheels for better access.
Old Sep 19, 2004 | 09:24 PM
BHP's Avatar
BHP
Heat gun.
To Rotor bracket question.
