Vibration at 80 mph!
Old Sep 20, 2004 | 08:37 AM
Red Thunder 03's Avatar
Red Thunder 03
Default Vibration at 80 mph!
Just installed a set of Z06 wheels on a 2004 Coupe. Used tape on weights all on the inside of wheels. Is it common to have a little vibration at 80 to 100 mph? It is my understanding that this is common with all the weight to the inside of the wheel and also the fact that they are after market wheels. Is this true, or do I need to have rebalanced? Thoughts and comments are appreciated.
Old Sep 20, 2004 | 09:01 AM
jrose7004's Avatar
jrose7004
I have aftermarket Y2K Chrome wheels with stickon weights on the inside and I don't have any vibration up to 130!
Old Sep 20, 2004 | 09:14 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Need to have them re-balanced....take them to someone who can RoadForce balance them....if the vibration doesn't go away you may have to spin the tire on the rim and rebalance...
oh yeah...make them strip the existing weights and start from scratch...
Old Sep 20, 2004 | 09:16 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Sep 20, 2004 | 09:28 AM
GR8-LIFE's Avatar
GR8-LIFE
I think its also known as On-Car-Balancing. I'm looking for someone who could do, not becasuse I have a balancing problem at 70-80 but because I Roadrace the car and on the straights I'm around 145.
Old Sep 20, 2004 | 09:37 AM
pewter99's Avatar
pewter99
actually its a bit different...the only reason I know about this problem is that fellow forum member Snake Slayer went thru this for 2 weeks....it was maddening....finally had them spin the tire on the rim and the problem was solved....good luck.
Old Sep 20, 2004 | 09:43 AM
GR8-LIFE's Avatar
GR8-LIFE
you are right. I just re-read "force balance". I didnt pay attention. On car balancing is the best way to go - but its expensive and they are tough to find. Had it done on my C4 many years ago but the shop is no longer there.
Old Sep 20, 2004 | 12:23 PM
johnlovescar's Avatar
johnlovescar
Old Sep 20, 2004 | 12:38 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I had the same problem and re-balancing on Hunter equipment with road force balancing got rid of it.
Old Sep 20, 2004 | 12:53 PM
If done properly, you should not have any vibration. My wheels are balanced the same and they do not have any vibration.
To Vibration at 80 mph!
