I received my Dynatech Supermaxx header system from Nate at Corvette Garage on Friday and by Sunday evening I had them installed. The sound is awesome with my stock Ti's. The additional torque and power is there and the sound is almost "exotic" as you go up in acceleration. The idle is deeper and with no resonance all the way through the power band. The fit and finish of this system is outstanding, and they fit like a glove. They were not a bad install, at all, the right side went in from the top and the drivers side went in from the bottom. I spent alot of time aligning the system and routing wires to hopefully keep them off any hot spots. I also changed plugs to the new Iridium Delco plugs.
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
Glad to hear the install went well. I ordered the LG LT's (no cats) today. They'll be on the 1st weekend of October. I pulled the full ls1howto.com program to a word doc so I'm bringing the laptop to the install.
When buying headers for the C5! Do I need to purchase the Cats too or just the long tub headers w/wo y pipe. Also, I assume it directly bolt's on to the Corsa exhaust?
Not too technically inclined just want to do it right the first time!
