Hoodliners
Old Sep 20, 2004 | 09:00 PM
OURRUBY's Avatar
OURRUBY
Spending his inheritance
Cruise-In VIII Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Hoodliners
I've seen many threads about hoodliners and have wondered about their longevity. I would like to put one on my 03 MY vert, but am leery as it is an everyday driver since our 2nd car is a 93 Ruby vert (see sig). Do these hoodliners stand up to the heat etc from the engine? Also, if I used it only for shows etc, would the holddowns/pins (or whatever they are called) hold up to the removal and reuse? Thanks for any imput
Old Sep 20, 2004 | 10:26 PM
C54TIM's Avatar
C54TIM
Mine held up fine.
The push in retainer pins won't last long taking them in and out. But there only 25 cents at the dealer. I'm sure somebody has them cheaper.
GO for it!
Tim
Old Sep 20, 2004 | 11:51 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default Hoodline
I have a hoodline which was painted by paula who is one of the verdors on here .Here is her e-mail if you would like to see her work.[url]HTTP://community.webshots.com/user/paulasartwork. name is Paula Hambrick-1-972-771-6022.Her email address is,paula75032@sglobal.net.
Old Sep 21, 2004 | 04:04 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Had mine done by a local guy who also did my fuel rail covers...no problems...mine is a DD as well
Old Sep 21, 2004 | 04:18 AM
markcz's Avatar
markcz
I painted my hoodliner myself using these instructions as a guide. I think it turned out pretty good.
A hood seal (or equivalent 'generic' for half the price at Lowes) will make it last longer.
Old Sep 21, 2004 | 05:26 AM
mike herhold's Avatar
mike herhold
Old Sep 21, 2004 | 12:03 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
You can find the replacement hood liner retainer pins at most any auto parts store and are fairly reasonably priced. The ones I bought have a different style clip that holds it in. These new ones are a lot easier to install and remove than the factory ones were. You can remove them by simply pulling out by hand, no special tool is needed for removal.
Only takes me a couple of minutes to remove/ install liner.
Old Sep 21, 2004 | 06:39 PM
charlene's Avatar
charlene
I have an 03 and i haven't had any problems taking the liner out to replace it with the new painted one i got from paula i just turned each one by hand a little and pulled it out very easy to do. Someone on here was talking about chrome ones i bet those would be really nice to have.
Old Sep 22, 2004 | 08:46 AM
OURRUBY's Avatar
OURRUBY
Thanks for the replies. Now to decide what design to get
Old Sep 22, 2004 | 01:09 PM
They last fairly well, but if you get a lot of dirt or water on them, they can be a little tricky to clean. I used to wipe mine down when I cleaned the car so nothing built up on the liner.
Old Sep 22, 2004 | 02:01 PM
Merlin02's Avatar
Merlin02
Originally Posted by C54TIM
Mine held up fine.
GO for it!
Tim
Wow, I need to start shopping where you shop. I just paid $1.49 each for the plastic hood liner pins at the local dealer.
Old Sep 22, 2004 | 05:50 PM
Z0SLIK's Avatar
Z0SLIK
They hold up fine.
To Hoodliners
