I recently purchased an 01 Vert A4 with 38K miles from a dealer. It's a GM certified car with a 3 year 36K mile bumper to bumper warrenty. My question is what is considered "normal" oil consumption? After about 1,500 miles it looks like I burned about 1/2 quart of oil. I've read that the 01 have ring tension issues. Is this considered excessive oil consumption and is it worth pursuing this with GM and or the dealer.
GM was re-ringing 2001s if the owners complained. There is a TSB out on that issue. I should think they would still re-ring your car if its GM certified. It was said that the "ring flutter" was caused by using to thin of a ring and would not really cause any damage to the engine. The problem is more evident with "lead footed" driving then with normal driving. I would indeed look into having the "fix" kit installed under your warranty.
I have an 01 coupe and generally the problem is mostly the MN6's cause of high RPM light load causing ring flutter. Anyway, if you are using 1/2 qt in 1500 you're fine I would not worry about that at all. If you start using a qt every 1200 then start the consumption test.
A 1/2 quart in 1500 miles is good. A quart in under a 1000 would be cause for concern.
I personally wouldn't even consider 1/2 quart every 1500 miles to be good. I've got 3100 miles on my first oil interval so far with my C5 and it hasn't used any oil at all. My wife's Honda has never used any oil in between changes.
Just little more info.....I had the re-ring done when I had my Head /Cam swap back in June. Not by the dealer either, I had the Tuner do it since the engine was already apart. So with that said, the oil consumption before re-ring was about 1qt in 1200 to 1500 as low as 900 once with black soot around tailpipes. Since re-ring no real consumption. According to the dealer whom I took the car to...the LS1 engine will settle down on consumption after about 18k miles. I bought the car with 7043 miles as time was progresssing it "seemed" like it was getting a little better at 12755 miles. However, before the H/C install the tuner did a leak down found most of the cylinders within spec...except number 7. So I told him just do the re-ring. Anyway, Bottom line if you're using a 1/2 qt every 1500 you are most likely ok. If it was me and my engine was using the same level I would leave it alone. LS1's do use a little oil.
When I had my rings replaced due to oil consumption, I was using a quart every 1200 miles. The standard at that time was anything in excess of a quart every 2000 miles was excessive. Check with your dealer and see if the policy has changed. 1/2 quart every 1500 miles may not meet the standard per GM.
1/2 Quart is normal for casual driving. Hard stop & go driving, up to 5,000-6,000 r.p.m., About one every 500-750. Racing, one burnt for 1.5-2 hours. A little oil burnt and very mild blowby is good to cool the rings on a high performance motor when you are putting your foot in it. Others, may beg to differ.
I was under the impression that the oil problem on 01 car's was only related to the Z06 cars and not the regular LS1's? Please set me straight here....
Oil comsumption affected all Z06's, ans LS1's(Corvette, Camaro and Malibu).
The 02-04 Z06, had 13 lb. tension Napier ring vs. a 7 lb. in 01 Z and the other LS1 motors. The oil issue in the 01 Z's was a little bit more pronounced, be driven harder than the lS1's, more compression, a year older(more miles than later models), etc.
Franky, I think(I KNOW) the stock rings, pistions and tolerances in all the late model GM cars suck. GM, could have made a warranty recall, but it would have cost them hundreds of millions. Instead they have attempted to hide the problem and fix this on a case by case basis, after you go through an inorbinate amout of work and finally complain that you are going to sue them. There are number sites on the internet that talk about this. This my opinion, but is supported by a lot of fact and actual experience.
Also, I mentioned tolerances. I have seen two of these blown factory motors stripped, the tolerances and bores checked and parts weighed. The Japanese or Germans would throw of these new motors on the junk heap if was their work, not even looking back.
