Need HID Installation Instructions
Old Sep 22, 2004 | 04:28 PM
Torched's Avatar
Torched
Default Need HID Installation Instructions
I'm going to have my HID 6000k kit installed tomorrow.I bought the kit from Matt Banks at Banks performance. Can somebody please provide me with instructions for a clean install. Much appricated. Greg
Old Sep 22, 2004 | 05:02 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
it's "plug and play"!
and self explanitory, took me a total of 15min to do both sides.
are you having someone do it for you?
Old Sep 22, 2004 | 07:17 PM
Torched's Avatar
Torched
Plug and play well see and yes i'm having somebody do it.Anybody else have instructions.Thanks Greg
Old Sep 22, 2004 | 07:24 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I found these in the tech tips section....not sure if it's what you need but hope it helps.
URL removed.....not relevant to topic...too late at night...... :o
Paul
Last edited by talon90; Sep 23, 2004 at 06:05 AM. Reason: Removed link for content
Old Sep 22, 2004 | 08:17 PM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
They are plug and play.
I installed the bulbs by turning the headlights on so the doors go up, then turn the headlights off leaving the parking lights on. The doors stay up. Remove the black headlight surround. (3 phillips heads screws)
You can now reach in and get access to the bulbs.
You take the low beam bulb out of the housing and disconnect the wiring plug that goes to it. You plug this wire to the HID ballast.
Mount the ballast with the double stick tape either on the frame rail or under the light housing. Put the HID bulb into the light housing. It is a
1/4 turn. Make sure you have it in properly or the light beam will be wayyyyyy off. It should be very close if correct. Plug the other lead from the ballast to the HID bulb. It took me about 20 minutes.
Old Sep 22, 2004 | 08:59 PM
Torched's Avatar
Torched
I Have the H-4 kit. TTT GREG
Old Sep 22, 2004 | 09:34 PM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Where Do I Get This Kit?
Old Sep 23, 2004 | 04:26 PM
RPOZ4Z's Avatar
RPOZ4Z
I hope you're paying him for the time it takes to do the job and not just a flat fee! LOL!
kidding aside, You're going to LOVE the HID's!
To Need HID Installation Instructions
