LED Tail Light Bulb Replacements
Red lense is like a filter. It allows light with "red" frequency to pass through, so the human eyes perceive the light as red. Now if you put "white" LED, most of the light produced will not be passed through the red lense because it gets filtered out.
I know I should be able to word that better, but hopefully you catch my point.
http://superbrightleds.com/1157.htm
in the 3157 with 20 LEDs flavor.
1. They are bright when I played with them in the lab.
2. When installed in a C5 there is a problem. The socket is offset and is intended to center a 3157 filament in the center of the reflector. When the very directional light from the LEDs is installed, the light does not fill lens.
Partly because it is pointed off center and partly because the beam width is too narrow. The LED array is too close to the lens. I may remove the plastic housing from the led array and see if I can get a better "fill" of the lens.
3. LED efficiency is changing VERY rapidly. I wouldn't buy anything designed more than a year ago.
4. I don't think there is any difference in the led whether molded in red or clear plastic. This is based on real lab tests, not just eyeball.
5. WHITE leds that emit a sorta white light have a very narrow emission in the red band produced directly by the die. They also have a very broad blue component which is generated by a phosphor, excited by the the red led die. Our eyes integrate the colors and it appears "kinda white". A "die" is the small chip inside the led package.
Comparing a RED and a WHITE led of equal optical power behind a red lens, the RED led would be brighter because the red lens filters out all except the red light. The same is true of an white incandescent lamp which really has all the colors, only the red component gets through the filter.
6. I've seriously considered building a circuit board for C5s, but it would not be a plug and play. It would be necessary to separate the red lens from the reflector which is a complete pain in the aaassss. The only other option is to slice open the reflector and drop in a pcb with the leds. That is also not too desirable. Plan C is to make an entire new assembly. Its not economically feasable at this point. A full set of 4 needs to retail for $200 tops.
Sorry if this ran on too long.
Barry
mtv
Frank
Frank
Wrong. I bought four of the 24 LED units from Ledtronics and also bought the wiring adapter harness separately from Adjure (the makers of C5 LED light kits). I then picked up an electronic flasher from Auto Zone (part # EL12) to plug into the socket that comes on Adjure's wiring adapter harness. My blinkers all now flash at the normal rate, as the led units go through the electronic flasher and the front incandescents go throught the stock flasher. "Plug and play" as they say.
BTW, I too noticed that the lights seem to show up as "points of light" so-to-speak, and I determined that this was being caused mostly by the leds that point outward in a radial pattern. I took a little silver paint and painted a 1/4" circle on the clear plastic cover, directly over these led's (there are six of them). These little silver painted areas act as little mini-reflctors and "diffuses" their light patterns much better as they are reflected off of the inside of the factory light assembly. HTH
Robert
. That gave me flashbacks to my college days!
