[Z06] Z06, Removable top?
Old Sep 24, 2004 | 11:44 PM
Al D's Avatar
Al D
Default Z06, Removable top?
Does the Z06 have a removable top? I looked at them and assumed no, but the copy of the MSRP sticker refers to "removable roof panel" "standard".
Thanks in advance
Al
Old Sep 24, 2004 | 11:50 PM
Matt69-ZO6's Avatar
Matt69-ZO6
NOPE. FRC (Fixed Roof Coupe) only.
Some aftermarket companies will do a conversion.
Old Sep 26, 2004 | 05:00 AM
PowerMad's Avatar
PowerMad
This is not a factory or dealer option. However, there are at least two companies that specialize in making a Z06 into a convertable.
Carvaggio (about $17k) gives you a convertable Z06 with a rag top and a bolt-on hard top. I have seen one of these conversions up close. It really looked great.
Advanced Automotive (about $11.5k) uses nearly all GM OEM parts in their conversion.
Burke Corvettes of Maitland, Fla specialized in completing he job. All th e brst
There are others... I am partial to the ones offereing a set that includes an automatic, retractable roof. Combine that set of features with those Lambo-style door openings... That is my fantasy car..
dave
Old Sep 26, 2004 | 06:27 AM
USA-VET's Avatar
USA-VET
$11,500 OMG!!!!! Buy a Vert then all all the Z06 crap you self, cost a lot less.
Old Sep 26, 2004 | 09:57 AM
Al D's Avatar
Al D
Thanks for the info. I'm torn between a Z06 and a convertable. I read the copy of the window sticker when I got home and it said "removable top" in the "standard equipment" section. I thought I could have it both ways without the big $ to do an after market change.
I'm still deciding between used and new. I'll see what kind of deal I can make before the 0% goes away.
Old Sep 26, 2004 | 10:49 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Al D - what people have mentioned to you about "aftermarket" conversions referenced, I believe, full convertible conversions of the Z06. Unless his price has changed recently, Caravaggio does a "targa" removeable roof panel conversion (akin to the OEM coupe) for $6500. Again the last time I looked, he had pictures of the conversion on his website. He also sells, or at least did sell, what is in essence a kit allowing your local body shop to do this conversion. I think a forum member in the Chicago area did this with good results. Good luck whatever you decide.
Old Sep 27, 2004 | 12:14 PM
TTRotary's Avatar
TTRotary
Caravaggio's price for the Targa conversion is considerably less: $6,500 if they do it in his shop, and $3,500 for just the parts. My understanding is this is time consuming, but not particularly difficult.
For the targa, there is no metal cutting. Just remove the HT, and blot/epoxy the new piece in. Of course, alignment is critical.
Old Sep 27, 2004 | 01:13 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Yes it is............and I LOVE IT TOO
Old Sep 27, 2004 | 01:27 PM
xsiveone's Avatar
xsiveone
I think it's cool looking and probably fun, but not for me. I'd rather keep the structural stiffness of the hard top.
X
Old Sep 27, 2004 | 06:30 PM
TTRotary's Avatar
TTRotary
This is a common misconception. In fact, the FRC roof has no structural value whatsoever, because it is 100% fiberglass with no metal reinforcements inside. From a structural perspective, the windshield frame (A pillar) and the roll hoop (B-pillar) are no more connected than they would be with an open targa.
The additional stiffness of the FRC/Z06 comes from it combining the Roadster's rear section bracing AND the Coupe's B-pillar hoop.
Old Sep 27, 2004 | 07:37 PM
xsiveone's Avatar
xsiveone
Then, why doesn't GM offer the car with a removable top? Same goes for the next Z06. It's reported to have the fixed roof as well with no removable top.
X
Old Sep 27, 2004 | 09:13 PM
TTRotary's Avatar
TTRotary
That is a long story, which has to do with marketing, but has no relation to engineering.
The abridged version is that GM originally planned to offer a "stripper" Vette to be sold mid 30s, which was short on features but high on value and performance. The stripper deleted the targa mechanism to save costs and about 20lb weight which was "spent" instead on adding the convertible's bracing. Thus, the fixed roof panel was budgeted for production, about 8K units/yr or so (IIRC). That evolved into the FRC which got most of the lux stuff and the higher price back, but kept the 1 pc fixed roof, since the units were already planned and budgeted for production. It didn't sell well, so the Z06 was born.
As for the next Z, we really don't know what is coming. DH has apparently stated it will be FRC, but who knows. I think there are a few surprises coming our way.
All I can tell you, is that on the C5 Z06, the fiberglass roof contributes absolutely nothing to chassis stiffness.
Old Sep 28, 2004 | 07:31 PM
Paul4137's Avatar
Paul4137
Default Z06
I just trade a 2001 vert for a 2004 ZO6 and would say there is no comparison. There is nothing like the ZO6. I rather loose putting the roof down for all ZO6 has to offer and drive around with the ac on if its that hot. Just my two cents. Good Luck
To Z06, Removable top?
