Fuel sensor problem in 2001
I was wondering if anyone else has had this problem? Have you had it repaired - and if so, what was the cost?
Also, any other recommendations?
Thanks!
May the urine of a thousand camels flow from the next shower taken by the GM engineer (pronounced "idiot") who designed the fuel sensor system. The BS about too much sulfur in the fuel is nothing but BS. No other car make has this problem (except on the very few rare occasions when there really was too much sulfur in the gas). For Corvettes, this is a daily occurance, and it doesn't matter what brand of fuel you use.
Just about every model has some sort of TSB addressing fuel gauge issues...
My Vette started to show this fuel problem about six months ago, started using BP exclusively, and the problem went away. (Maybe it was for another reason, not sure.)
My Jeep started showing this same problem coming back from Utah, and the problem did not go away. Dealer replaced the sending unit, the finish on the contacts had worn off. Per the dealer, this is not unusual.
It is a problem due to different fuels, and since GM does not make the sensor, the same designed sensor can be used on other vehicles. The coating on the sensor wears off due to sulfur, and some fuel manufacturers allow different amounts of sulfur, up to the government maximum requirement. Some fuel companies such as Chevron, BP, have lower sulfur requirements for their fuel.
Could they make the sensor so that sulfur does not affect it? Yes, and all manufacturers should use a sensor that is not affected by normal amounts of sulfur.
The problem with my Jeep had nothing to do with the Marathon problem in KY, or the Shell problem in the south were excessive amounts of sulfur was distributed in the fuel by mistake.
My Chevy S-10 and Firebird (both currently in my stable) have never had any problem with the gauges, and they still use the BP gas. My Montero has never had the problem either, nor has either of my brothers' two Jeeps.
It just plain sucks.
rr
http://calid.gm.com/vci/VINEntryPre.do
I do use Chevron gas, and have for the past 15 years in my vehicles. I just bought the Vette back in February, so I'm not sure what fuel was used in it prior. But, I have put about 6,000 miles on it with the Chevron Premium. And like I mentioned, sometimes it works just fine (it actually has been recently). The problem I had with it about a month ago, it would stick on full. I had a '91 Mustang for 10 years, and never had a problem. Then I had a '01 Mustang for 2 1/2 years, and had a slight problem with the guage. So I'm not sure if it can be just a GM problem or not.
