Passenger window will not go down. I can hear it click when I press the button but window does not move. No hints it was about to go out...it was working fine one day, then it just stopped working??? Any suggestions? Thanks in advance. Craig
Right side window motors get a dead spot in the motor due to being used less than left side.You will find that if you tap the motor with a hammer,it will start working again
