Mileage question???????
Old Sep 26, 2004 | 08:11 AM
keyscat's Avatar
keyscat
Default Mileage question???????
I've had my '04 C5 for 4 months now. I drive 50 miles to
work every day, all highway. When I first started I got
27 MPG. Since my oil change I'm getting 24. Same driving
habits (I cruise at 55-60 mph)
My '01 also got 27mpg. Anyone have any answers?
Thanks in advance
Old Sep 26, 2004 | 08:18 AM
mowton's Avatar
mowton
When they change the oil, they must idle the car for some time period to check for leaks. This reduces the average MPG by a substantial amount. Does take a fair amount of driving to build it back up.
Not sure how long ago you got the oil changed or if you reset the AVG MPG when you got the car back. Best I can comeup with at this time.
Old Sep 26, 2004 | 10:12 AM
jrose7004's Avatar
jrose7004
I'll bet when you reset the mpg it'll be fine!
Old Sep 26, 2004 | 02:17 PM
keyscat's Avatar
keyscat
Thanks for the responses....I never reset the AVG. MPG
Old Sep 26, 2004 | 02:20 PM
lvvette777's Avatar
lvvette777
That'll do it!!!!
Old Sep 26, 2004 | 02:26 PM
GrayC5's Avatar
GrayC5
That should fix you up.
Old Sep 26, 2004 | 05:57 PM
Weather conditions and traffic flow will also affect it. Saw you haven't reset the MPG indicator - that would help you see if you are still getting the higher MPG.
Old Sep 26, 2004 | 06:01 PM
lvvette777's Avatar
lvvette777
I just thought of something:
Are you sure they used 5-30 oil?? If they used a higher viscosity when they changed your oil your mileage could suffer a little bit because the oil takes longer to flow readily through the engine causing reduced fuel mileage for the first few miles.
A long shot but just a thought.
Old Sep 26, 2004 | 06:16 PM
mowton's Avatar
mowton
Good question -- I assumed Mobil 1
Old Sep 26, 2004 | 06:17 PM
lvvette777's Avatar
lvvette777
Mobil 1 comes in many different viscosities, if they used a different viscosity than what you had in there, your mileage could suffer.
Old Sep 26, 2004 | 08:10 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I get between 14 and 33 mpg depending on conditions..what a car...
Old Sep 26, 2004 | 08:39 PM
johnlovescar's Avatar
johnlovescar
I get am an average of 20 mpg. Before I install some after market products, I was getting around 22 mpg. Even those I lose on the mpg, I GRAIN ON THE PERFORMANCE......
To Mileage question???????
