Ok I have a turn signal out on the drivers side......the indicator inside the car flashes really fast........
I dont know how to get to it to change it........
well problem #2
the passenger side indicator now flashes realy fast.........and stays lit and on even when it's not engaged so as to turn right.......
I checked the front of the car and the right turn signal appears to be working........only it's a bit dim.........
can someone assist me in how to get these changed , or possibly point out any other problems?
well to change, I go in through the front brake duct and push it back and down. I reach my arm in there and grab the harness and twist off and pull it back through the duct and change the bulb. Then put back in and replace duct back in place. Others try to raise the car, or go behind the head lights, but I couldn't do that. Good Luck.
well problem #2
thanks in advance
There is an access panel between the bumper and front wheel. remove the 7mm hex screws and you'll have full access. It may need the car lifting or hang the front end off of the curb by your driveway to give you some clearence.
