40# recommended tire pressure?
Old Sep 27, 2004 | 08:08 PM
Great White Shark's Avatar
Great White Shark
Default 40# recommended tire pressure?
Took the C5 in for an alignment today and the tech told me I was crazy to put in 30psi cold. He has been around many years and his alignments are the best I have ever found. He claims 40psi will give me longer tread wear (which is cool with me). I am confused and am turning to my brethren of the forum. Any feedback greatly appreciated!
I am running stock runflats.
Old Sep 27, 2004 | 08:11 PM
BigJoe's Avatar
BigJoe
Hmmm the user manual says 30 the door sticker says 30. Both written by GM. Guess it boils down to who do you trust, all of GMs engineers or one alignment tech...
Old Sep 27, 2004 | 08:15 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
I've usually run about 30 cold in my OEM Goodyears............37K miles and the fronts are good for another 5 or 6. Replacing all 4 soon though.
If they drop to 27 or 28 in cold weather.........I don't add.......they warm up pretty quick to 30
Old Sep 27, 2004 | 08:17 PM
lvvette777's Avatar
lvvette777
I hope you have a good dental plan because you will be jarring your teeth out at 40 psi.
Old Sep 27, 2004 | 08:18 PM
mowton's Avatar
mowton
40 at cold translate to +45 at temp; If I'm not mistaken, this is not good for the sidewalls of a radial. You may have tread but.........
I'd be careful with this info.
Old Sep 27, 2004 | 08:19 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Old Sep 27, 2004 | 08:22 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Not to mention seeing the high tire pressure message on your DIC everytime you start it up!
Old Sep 27, 2004 | 08:23 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Geez - the stock EMT's ride like wooden wheels on an ox-cart, when inflated to 30 psi.....
I cannot even imagine what they would be like at 40 psi
Sorry - I have to go with the GM recommendation - 30 psi.
In Arizona, I usually keep my BFG KDW's at 28 psi cold - which takes them to about 31 - 32 hot.
Old Sep 27, 2004 | 08:25 PM
C5 4 ME's Avatar
C5 4 ME
I could be wrong but I believe you will receive "high pressure" messages on the Dic from the tire sensors with 40 + lbs. I run 30 lbs cold. Hope this helps.
Old Sep 27, 2004 | 08:26 PM
StevieB's Avatar
StevieB
Over inflation will cause premature wear in the center of the tire.
Old Sep 27, 2004 | 08:27 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
30 cold...
Old Sep 27, 2004 | 08:28 PM
Railfan's Avatar
Railfan
My tech also tried to put 40 # in my tires (runflats) until I showed him the inside of the door. We put them back to 30#. Actually, I run them at 28 so that when they warm up they are at 31-32.
I don't believe the techs are familar with run flat tires.
Old Sep 27, 2004 | 08:55 PM
RCK1999's Avatar
RCK1999
I bet the tech also sells tires. Get them worn out ealy, get a sale on new ones
Old Sep 27, 2004 | 09:49 PM
Fritz Hier's Avatar
Fritz Hier
Yeah, and lots of wheel hop! When I bought my car new, every time I would get on it just a little bit and the tires started to spin, MASSIVE wheel hop. Took me about a day to realize it was the tire pressure. put it down to 30, pure tire spin and grab!
Old Sep 27, 2004 | 10:05 PM
jschindler's Avatar
jschindler
Don't do it! Premature wear in the center, poor ride, reduced traction. Not a good combination.
Old Sep 27, 2004 | 10:06 PM
GrayC5's Avatar
GrayC5
And, the GM service manual says 30 psi. When the tire pressure goes above 42 psi the Tire Pressure Monitoring System will display the High Tire Pressure warning message. Starting with 40 psi in you tires, it won't take many miles of driving before your tire pressure goes above 42 psi.
Old Sep 27, 2004 | 10:13 PM
Evil-Twin's Avatar
Evil-Twin
Your Alignment tech must spend his nights at his second job playing the village Idiot...
30 psi is the right number.. the only difference I have is my 30 psi is based on Hot tire pressure.. based on road conditions , just like any winston cup or nascar, formula 1 car tire pressure is set up.. they monitor the road temperature and adjust it accordingly to get the most milage out of the tires.. Personally , using this approach I got 43,000 miles out of my first set of EMT's...
I never allow my tires to get over 30 psi hot !!
To 40# recommended tire pressure?
Old Sep 27, 2004 | 10:17 PM
lottavettes's Avatar
lottavettes
Nine out of nine Chevy Dealers Ive dealt with say 35 lbs is best. Another 5k miles at least over 30....
Old Sep 27, 2004 | 10:29 PM
Evil-Twin's Avatar
Evil-Twin
So you have had to deal with nine different dealerships, and they still cant get it right I see..
Old Sep 27, 2004 | 10:31 PM
Sorry, but no way I would put 40 lbs pressure in the tires. Good way for the center of the tread to wear out very quickly. 30 psi cold is what is recommended by GM and the tire manufacturers.
