Battery Tenders?
Old Sep 28, 2004 | 04:58 PM
Railfan's Avatar
Railfan
Default Battery Tenders?
I know this question has been answered before, but I can't find the thread. So here goes: I would like a recommended list of battery tenders, prices, (and where you got them). My 99 coupe will be hibernating within a couple of months, and I need to get prepared.
Thanks,
Mike
Old Sep 28, 2004 | 05:25 PM
FKING1's Avatar
FKING1
Deltran Battery Tender is the best IMO. www.batterytender.com. Have 3 of them. Believe they are around $60.
Fred K.
Old Sep 28, 2004 | 06:37 PM
I bought a Sears Battery Maintainer (Diehard) and it has worked just fine. Cost about $30.
Old Sep 28, 2004 | 06:42 PM
wireless's Avatar
wireless
Photochop Terrorist
Sounds like chicken tenders. I got the Battery Tender Plus (or whatever the full title is) from one of the forum vendors.
Old Sep 28, 2004 | 07:20 PM
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Hey! Support your Corvette Museum - they still sell them at $59.95, and if you're a member, you'll get 10% off!
contact the store and check it out!
http://www.corvettemuseum.com go to the Corvette Store and and check near the bottom of the "auto & essentials" area
Hope it helps!
Old Sep 28, 2004 | 07:29 PM
Richin Chicago's Avatar
Richin Chicago
Thanks,
Mike
This one works fine for me.
http://www.remybattery.com/350/shope...%2E&subcat=332
Old Sep 28, 2004 | 07:33 PM
Dave1998's Avatar
Dave1998
I bought mine at Harbor Freight
$ 15.
works great !
Old Sep 28, 2004 | 07:40 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Walmart has a beauty that sells for about $16. It is made by Vector. I used it all last winter and it works like a charm. Has a red led that lights up when charge is applied. I'll be hooking it up again in a few weeks here in Michigan.
Old Sep 28, 2004 | 07:43 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Hope it helps!
Totally!! Great place to visit and support.
Old Sep 28, 2004 | 08:11 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I think mine is identified as a "Battery Tender Plus" and went for about $20.00. Picked it up from one of the forum vendors. You need to make sure its a true "Tender" type and not a trickle charger, which as I understand it, can do some real damage.
Old Sep 28, 2004 | 08:12 PM
c5BlackBeauty
Lifetime Member
I think mine is identified as a "Battery Tender Plus" and went for about $20.00. Picked it up from one of the forum vendors. You need to make sure its a true "Tender" type and not a trickle charger, which as I understand it, can do some real damage over time. Good Luck.
Old Sep 28, 2004 | 08:16 PM
1Patriot's Avatar
1Patriot
I use 3 of the Harbor Frieght models. Had them for years and they still work fine on the RV and Corvette batteries. Use to keep them attached to the boat throughout the winters and in the spring the boat was always ready to crank.
Old Sep 28, 2004 | 08:39 PM
JoesC5's Avatar
JoesC5
$ 15.
works great !
Have three from HF. Bought on sale for $9 each. Have used for 4 or 5 years.
Old Sep 28, 2004 | 08:41 PM
jerrymcb's Avatar
jerrymcb
Thanks,
Mike
I would strongly recommend a VDC Electronics Battery Minder
or the Deltran Battery Tender Plus. You can leave either of these on
indefinately with no fear of battery damage.
Old Sep 28, 2004 | 08:46 PM
Railfan's Avatar
Railfan
Thanks to all who answered. Besides Walmart or online vendors, where can I pick up some of these beauties?
Mike
Old Sep 28, 2004 | 08:52 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Best price, for the best and the ORIGINAL Battery Tender $33.95 Battery Tender Plus
Don't settle for second best.
Old Sep 28, 2004 | 10:14 PM
TOBASCO's Avatar
TOBASCO
NCM Ambassador
Nobody's mentioned it, but make sure it is a battery "tender" and NOT a trickle charger.
Old Sep 29, 2004 | 06:16 AM
XTrooper's Avatar
XTrooper
I have the "Battery Tender" brand version. They all cost about the same. Go buy one.
Old Sep 29, 2004 | 07:07 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
I've been using the Sear's brand for years with no problems...
To Battery Tenders?
