Help!
Old Oct 1, 2004 | 07:17 PM
webdzynes's Avatar
webdzynes
Default Help!
My gas cover won't open and I'm on the road. Where is the manual release located? (...and is this a fuse operated thing?)
Old Oct 1, 2004 | 07:23 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Open up the center console and you'll see a button towards the front of it. If it won't open that way, there is a tab located against the upper trim on the driver's side in the rear compartment. Pull it to manually release the fuel filler door.
Old Oct 1, 2004 | 07:32 PM
webdzynes's Avatar
webdzynes
Opened the drivers side rear storage and cant find anything. Is it in/around that compartment or behind a panel? Its a 98 if that makes a difference
Old Oct 1, 2004 | 07:36 PM
Antonio BananaS's Avatar
Antonio BananaS
wow...you must have a laptop with wireless internet access. *envy*
as far as the cap opening thing, i'm not the right person since i know sh*et about cars period. sorry but good luck!
unchained's Avatar
unchained
Cruise-In VI Veteran
Cruise-In VII Veteran
Is the button in your console not working???
Old Oct 1, 2004 | 07:40 PM
webdzynes's Avatar
webdzynes
no, the button doesn't work. (Maybe as fuse thing, I dont know)
Old Oct 1, 2004 | 07:43 PM
ExRedRacer's Avatar
ExRedRacer
Might be behind some panel...I got the previous info from my '02 Corvette manual...
You may have to take a look up behind some stuff. Sorry can't be more help.
Maybe someone with a '98 will chime in...
Old Oct 1, 2004 | 07:50 PM
unchained's Avatar
unchained
OK, I just went and looked at mine... Mine is an '04; I don't know if yours would be any different or not... but the manual release cord was not IN the rear storage compartment. It was sort of up underneath the top rim of the left wall. Open the hatch and run your hand underneath the upper lip on the driver's side and you should feel it ... if it's in the same place as mine.
Old Oct 1, 2004 | 07:51 PM
C5 4 ME's Avatar
C5 4 ME
I just went out to the garage and looked in the rear compartment of my 98 Coupe. On the left hand side in the rear hatch area, I have a tag sticking out of the carpet that reads fuel door release or something like that. It is attached to a wire that will release the gas door. I hope this helps.
Old Oct 1, 2004 | 07:52 PM
ExRedRacer's Avatar
ExRedRacer
It's hard to describe...there's a little plastic tab that sticks out from between the trim panels in the upper portion of the rear compartment. If you stand exactly at the back of the rear wheel, it's directly above that point in the rear compartment.
I went down to my garage to find it myself. Good luck with yours.
Old Oct 1, 2004 | 07:57 PM
rescue7's Avatar
rescue7
Default door release
Look above rear storage door driver side along edge below Where hatch comes down to meet body just looked on my 99
webdzynes's Avatar
webdzynes
Thanks - but no luck. Nothing there. Any other suggestions? It's a 98 coupe
Old Oct 1, 2004 | 08:00 PM
Antonio BananaS
that button is to generate 50 more horse power to make c5 run like z06. you are a woman...of course you wouldn't know.
unchained's Avatar
unchained
It's got to be there. That's where it is on everyone else's who answered. I wonder if the plastic tag came off?? Can you feel any kind of wire around the top of that side panel on the left side of the trunk area??
JCR_Indy's Avatar
JCR_Indy
If you're standing in back of your car and looking into the rear compartment - look at where the gas door would be if it were on the inside - you should see a little wire (with a yellow tab) which should manually open your cap...
JCR_Indy
Old Oct 1, 2004 | 08:03 PM
unchained's Avatar
unchained
But I bet I can take a glove box apart faster than you!
Old Oct 1, 2004 | 08:04 PM
webdzynes's Avatar
webdzynes
THANKS GUYS - FOUND IT! i OWE YOU ALL A BEER!!!
To Help!
Old Oct 1, 2004 | 08:05 PM
rescue7's Avatar
rescue7
Run your hand along the the hatch opening under the edge inside along the side of the hatch inside its hanging there just about where the rear wheel is
Old Oct 1, 2004 | 08:06 PM
unchained's Avatar
unchained
YEA!!!!!!
Old Oct 1, 2004 | 08:17 PM
C5 4 ME's Avatar
C5 4 ME
YEA!!!!!!
