Difference between TigerShark and Pro tips on Corsa?
Old Oct 2, 2004 | 01:09 PM
PaceThis's Avatar
PaceThis
Default Difference between TigerShark and Pro tips on Corsa?
I know the tigersharks are closer together in the center, but are they a different tip design as well?
I'd love to see photos of both for comparison sake!
Old Oct 2, 2004 | 02:52 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Maybe this link to Corsa Performance might help.
http://www.corsaperf.com/c52.htm
Old Oct 2, 2004 | 04:36 PM
PaceThis's Avatar
PaceThis
The tips themselves look pretty much the same to me...
Anyone seen both in person?
Old Oct 2, 2004 | 04:43 PM
2000droptop's Avatar
2000droptop
St. Jude Donor '07
I have the tigershark tips. The tips themselves are identical to the pro tips. It's the spacing that is different.
Tigershark= 4 inline equal spacing
Pro = 4 inline 2+2 grouped with space in between the groups.(stock look)
Also, Tigershark are not as common.
Get the Indy's with x-pipe,I did You'll love them
Old Oct 2, 2004 | 06:16 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Tips are identical, Tiger Sharks and Pro tips.
Old Oct 3, 2004 | 12:01 AM
NVR2L8's Avatar
NVR2L8
I have the Tigershark tips, and agree that they are the same.
More importantly, though, is that I GUARANTEE that you will not be able to keep the Tiger Shark tips perfectly aligned without constant readjusting. I have had mine installed for over a year, had them readjusted at least half a dozen times. Talked to Corsa numerous times, suggested that they make some type of clamp to keep them aligned, but all I got was lip service. At the Mid America Funfest, Corsa had a C5 with Tigershark tips, and even their demo car had the tips out of alignment! Finally, I had my muffler shop weld a small rod behind the center tips (out of sight), and so far they are staying aligned.
Good luck.
Old Oct 3, 2004 | 01:12 AM
2000droptop
St. Jude Donor '07
I've not had the same problem with alingment. The first 500 miles or so I noticed a little varaince. I re-tightened them and so far have had no mis-alignment after 2 years and 10,000 miles
Old Oct 3, 2004 | 04:17 PM
PaceThis's Avatar
PaceThis
Thanks guys! That's what I wanted to know. I had the indy GTR tips on pace #2...tips with Corsa have always had alignment issues...but then again, so have stock tips.
Once installed, I'd highly suggest having a muffler ship weld a pc of metal along the back top of the tips that ties the two sections together...I think it's the only way on some cars to keep them aligned...
To Difference between TigerShark and Pro tips on Corsa?
