Just installed hurst billet shifter.
Old Oct 2, 2004 | 01:12 PM
Jimdear00Coupe's Avatar
Jimdear00Coupe
Default Just installed hurst billet shifter.
man what an improvement. Tight accurate shifts
a bit on the stiff side but Still great improvement over stock.
Old Oct 2, 2004 | 01:28 PM
NSTG8R's Avatar
NSTG8R
I may be wrong, but i think you can adjust the stiffness on those shifters.
Old Oct 2, 2004 | 01:34 PM
Jimdear00Coupe
You are correct you can adjust the stiffness. I'm gonna let it break in a bit before I adjust it.
Old Oct 2, 2004 | 07:13 PM
gyoung's Avatar
gyoung
Great mod - I like the stiffness, good positive feel imo
Old Oct 2, 2004 | 07:50 PM
mlupone's Avatar
mlupone
sounds great
how much did the new shifter cost and how long did it take you to remove and replace?
Old Oct 2, 2004 | 11:10 PM
billiam01's Avatar
billiam01
The stiffness can be adjusted (didn't you get directions with the shifter?) but it doesn't make much difference; maybe over time it will loosen up. But I love the feel of my new Hurst shifter; it has taken my enjoyment of driving my vette to a new level.
Old Oct 2, 2004 | 11:27 PM
mdhmi's Avatar
mdhmi
I paid $155ish for mine and I absolutely love it. Did you keep the stock shift-****?
Mark
Old Oct 2, 2004 | 11:32 PM
Congrats on installing your new shifter.
Old Oct 3, 2004 | 12:56 AM
phear_this_mind's Avatar
phear_this_mind
I HATED mine and I've used plenty of short throw shifters. I'm a strong guy and I found the stiffness to be completely unacceptable and I adjusted it as much as possible.
The B&M short throw was a significant improvement over the hurst, but I may have just had a dud.
Old Oct 3, 2004 | 01:19 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I love mine. The best mod in the car.
Old Oct 3, 2004 | 03:01 AM
Jimdear00Coupe
Paid 173 shipped from jegs. took about an hour. instructions that came with it are not bad but there is a thread on the forum with pics that helps a lot.
Old Oct 3, 2004 | 03:02 AM
Jimdear00Coupe
Yes kept the stock ****. No noise as some have reported here on the forum.
Old Oct 3, 2004 | 09:05 AM
drosenth's Avatar
drosenth
Question - did you use the stock boot or purchase one that fits better? I will be soon installing my Hurst, and I didn't know if I should invest in a better fitting boot. Right now I don't think I will, but if it is really needed to make the job look perfect, I will. I just don't want to take this thing apart twice.
Thanks,
DaveR
Old Oct 3, 2004 | 11:08 AM
Patches's Avatar
Patches
Near the end of the tutorial linked below are a few pics of the short boot I got from Vette Essentials.
(http://www.vetteessentials.com/)
Hurst Install
Old Oct 3, 2004 | 11:22 AM
gyoung's Avatar
gyoung
Originally Posted by mlupone
sounds great
Don't remember the exact price - 150-200 range. The install probably took a couple hours.
Old Oct 3, 2004 | 10:15 PM
Sprags2004's Avatar
Sprags2004
sounds great
I finally got around to installing mine today as well. I started at 9:30 this morning and everything went wrong. I ended up destroying the key trying to get it out and my only alternative was to saw the shifter shaft to get the **** off. Then my girlfriend and I broke up. Then I dropped a screw down in the tunnel. After running out to the parts store to get one of those flexible parts grabber thingy's and getting the screw out the installation went fairly smoothly. Finished up around 3:00PM.
Now I find out I gotta remove the exhaust tips to install the Exhaust Plate.
Oh well...I'll get to that before I head up to Chicago next weekend to see my friends and family and show off the new ride.
I got an aftermarket shift **** on now and it looks cool and works beautifully.
Old Oct 4, 2004 | 02:44 AM
Jimdear00Coupe
Default Stock Boot
Thanks,
DaveR
Used the stock boot. Looks good to me. I'll try to post a pic of it.
To Just installed hurst billet shifter.
Old Oct 4, 2004 | 03:47 AM
bluemax1724's Avatar
bluemax1724
St. Jude Donor '06-'07
Hurst Install
By your picture showing both the stock and short boots, it looks like the lower portion of the stock boot could be trimmed to the length of the short boot. I can't tell if the shortened stock boot would have enough material left, around its perimeter, to attach to the boot mount though. What do you think? If you think the stock boot could be modified, approximately how much would have to be removed to match the short one?
PS Thank you for the detailed install info.
Old Oct 4, 2004 | 06:40 AM
Sprags2004's Avatar
Sprags2004
Though you may be able to shorten the stock boot I would hesitate to do so...It really does look OK with the stock boot and the short shifter.
Old Oct 4, 2004 | 06:48 AM
Patches's Avatar
Patches
You might be able to shorten it a bit but be careful. The diameter of the boot will decrease as you cut a section from the bottom because of it's conical shape and you probably won't be able to pull it over the ring. I suggest either using the stock boot unmodified or buy a VE boot which is cut to fit the stock ring.
