Alternator appearance
Old Oct 3, 2004 | 09:46 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Default Alternator appearance
As a 97 with 50k on the clock my alternator is looking a little weathered with oxidation. Is there any safe way to clean or polish the casing of the alternator to make it look a little brighter/cleaner? Thanks in advance for any replies.
Paul
Old Oct 3, 2004 | 10:10 AM
gtzy's Avatar
gtzy
metal polish and a toothbrush will improve its appearance
Old Oct 3, 2004 | 02:53 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
and the polish to use is Simichrome. It's not cheap, but a little bit goes a long way.
Old Oct 3, 2004 | 06:46 PM
talon90's Avatar
talon90
NCM Ambassador
Thanks for the replies. I just wasn't sure if I could safely polish it with out risking damage to the windings. I'll look into the polish recommended.
Old Oct 3, 2004 | 08:53 PM
ROJ#79's Avatar
ROJ#79
You can take a can of alumium spray paint, spray some on a cloth and rub it on to the part. If you don't like the appearance of it , it can be removed by using mineral spirits before it dries.
It does a fairly nice job and you might like it.
Make sure you clean the part good first so the paint will stick before you apply the paint.
Old Oct 3, 2004 | 09:16 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I forgot to mention... you don't need to order it online (unless you prefer to). Most BMW motorcycle shops carry it.
Old Oct 3, 2004 | 09:38 PM
Semichrome is a very good polish - I used to use it all the time on my motorcycle and it really does the job.
Old Oct 3, 2004 | 09:42 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
i use a small brass bristle brush for the parts under my hood. it knocks off all the oxidation good.
To Alternator appearance
