remove a locking lugnut that I've lost the key to without permanently damaging the wheel or breaking the stud?
Lost the key to my Gorilla locking lugnuts. Called Gorilla. No joy. Got to have the code key to get a replacement key.
The stock lugnuts are 3/4 inch. Do I buy 3/4 deep well socket, hammer it over the locking lugnut, and then use a breaker bar? Or is 13/16 or 7/8 the right size to use?
Need your experienced help before I REALLY screw something up!!
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
There are a couple of options - Snap-On tools makes a kit that should remove MOST of the wheel locks.
If you don't want to buy the kit (understandable - how often will you need it?) you might try going to a dealer, or a shop that does a lot of work on wheels and tires - and inquire as to whether they have the aforementioned kit and whether they would be willing to assist you.
You can try a 7/8 or 13/64 socket (whichever is a tighter fit), find another socket like it that you're willing to throw away (chances are it''ll get wrecked), hammer it on (watch your fingers!) and try a breaker bar.
Sorry - that's the best advice I can offer. There was a video clip that one of the Forum member posted here a while back, that I can't seem to locate - maybe someone will chime in with a link to that clip. It showed the second option....... http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
I'll bet if you took a close-up picture of it (and made it obvious that it belonged to you) that they would be able to find a match for it. I bought two different sets of Gorillas and the keys match! And I wasn't even trying!
