[Z06] Clutch pedal sticking - please help
I have read a few posts about clutch pedals being stuck to the floor after hard acceleration. Happened to me for the first time last night. Was I just riding the clutch too much or do I need to have something replaced? If the latter, does anyone know whether this is covered by a service bulliten? Many thanks (because this kinda freaked me out).
BTW, if it matters, I have an 04. Thanks again.
1 Post
St. Jude Donor '05-'06
MikeO.
I have seen it on my 01, but only at the track when I am launching hard at too high an rpm. It seems like 3500 and a fast, not dump is the way to go, and 4000k on a track that is prepped well. Don't know about a TSP, but I thought there was a fix on the older cars: 04 Z parts. My car is out of warrenty so I am thinking bigger stiffer clutch and 04 Z parts but if your car is doing it now????? I will follow your post and hopefully someone will chime in.
Dave
PS discovery channel has a C6 special on, so much for washing, waxing and then the track next hour!
Dave
MIne did for the first time last week and I got caught in the heavy stop and go traffic during the last hurricane. I am relatively certain it was caused by the clutch getting too hot.
I would like to see a copy of the TSB on this and take it to the dealership when my car goes in for warranty work again.
All I could find was this:
TECHNICAL SERVICE BULLETIN: MFG Bulletin Number: 051602
MFG Bulletin Date: 20020516
Component: POWER TRAIN:CLUTCH ASSEMBLY
Details: COMPLAINTS OF THE CLUTCH PEDAL NOT RETURNING WHEN DEPRESSED. *TT
MCS Check Date: 20030805
I've had the same problem since I installed my magnusson supercharger that I purchased from Lingenfelters'. It used to do it very often due to the pressure plate. So I gave Daniel a call at Spec Clutches and he sent me a Stage 3 clutch with an aluminum flywheel. Since that day it hasn't hapenned once. Great service and pricing from Spec.
Originally Posted by mikeo
Can you please explain "EXEDY"? Thanks.
He is suggesting replacing the stock clutch with the aftermarket Eexedy clutch. And as much as I may agree with him that the Exendy is a fine clutch. I don't feel that we as consumers should have to pay to replace a clutch that is failing due to poor design or quality control on GM's part. If GM is willing to pay for the labor costs; I would be willing to pay any additional amount above the OE clutch to get the Exedy put in. But, I don't think the General is going to go for this.
Originally Posted by Z06ufgrad2002
I think he was yanking your chain.
I couldn't agree with you more. I had posted this in another thread a few weeks ago, but I guess I'll say it again. I found out less than 2 months after I had my Z just how weak this clutch is. I just decided one day to do a stand-still punch and phew..clutch burn. And believe me, I am not a crazy driver, so my clutch had been babied up to this point.
I guess what I'm saying is that the weak link in our Z's is this clutch. Some people have had some longevity with their clutch in their Z's, while others (like myself) have decided to take matters in to their own hands (and pockets) and solve the problem. It is a shame that GM "cheaped out" and didn't put a clutch in worthy of this 405 bhp engine...but so be it.
1 Post
Seems like changing the fluid very often helps too. I change mine almost every time before I go to the track and it helps. Damn, I was hoping LTs would be next but it seems like a cluthc is next. Thanks!
Dave
Dave
I just took m y 02 to my dealer to have the same problem addressed - I gave the service manager the print of the tsb that someone here provided me a few weeks ago - and he kept the car for the day.
They ordered a new slave cylinder and master cylinder for the clutch - he called me today to say that it was in and he could get the car done anytime.
I will let you know if this fixes the problem.
I only notice this when I rev it to redline and shift - and I notice no slippage at all at any time.
best regards -
mqqn
Originally Posted by TT_Vert
where can i find a copy of that TSB? My dealer needs one too
dave
dave
Just call your service manager and tell him about the problem you are having. Tell him that your clutch pedal does not return under hard, high RPM shifting.
Here is the info repeated from above in this thread.
They replaced the clutch master and slave cylinders, which involved removing the torque tube and transaxle etc. Not for the weak of heart, but you do get to inpect the components pretty closely. What I thought was a leaking seal on the differential was actually just oil blown out of the breather on the top of the unit.
BTW - You could have a heavy clutch installed at this point for little additional $ if you have a good service manager...
The work was done under warranty, at no charge, on my 34k mile 2002 Z06.
I have not had any more "clutch pedal on the floor syndrome" since this was addressed on my Z.
That said, the problem did not manifest itself until I had 20k miles on the car or so. I am suspicious that I may run into this again at 60K miles, but I'll cross that bridge when I get there.
best regards -
mqqn
Here is a link to the VME (not TSB):
http://forums.corvetteforum.com/show...ght=TSB+clutch
See C5-TECH's post.
Make sure the new clutch assembly is properly balanced. See also: http://forums.corvetteforum.com/showthread.php?t=934650
I spoke with a Z06 owner who had the sticking clutch problem fixed: his clutch pedal vibration was also fixed after the repair.
clutch pedal sticking
I road race my Z and had the same problem. The dealer was no help,in fact they voided my warranty because of the harness bar in my car. I changed the fluid in the master cylinder to ATE Super Blue Brake Fluid ( many of the Porsche road racers also use it) and drilled several holes in the lower half of the bellhousing to vent the hot air out of the clutch area (the two small vents on the bellhousing are not enough). Since I did this the problem has disappeared. I believe the design of the clutch which incorporates the slave cylinder inside of the bellhousing causes the clutch fluid to overheat when used hard, which leads to the slave cylinder sticking.
Clutch Sticks
I went through this on my 01 Z06. The GM warranty solution was to replace the master cyl, slave cyl, flywheel, pressure plate, and clutch disk. GM sent the dealer a "kit" containing those parts. No problems since the change.
