Low oil level
Old Oct 4, 2004 | 06:30 PM
hawki's Avatar
hawki
Default Low oil level
I am posting this from the Baymont in Bowling Green. Went to the plant and museum this morning. Spent the afternoon running around, shopping, etc. I started the car up for about the 20th time and got a "low oil level" message, checked the oil and it was down a little less than a quart, added oil and the message did not go away. I did a reset on the dic and the message disappeared, as soon as I restared the car the message came back, all gagues look normal. I am hoping this is just a computer issue. Some one plese telle that is all that is going on. Thanks,hawki
Old Oct 4, 2004 | 06:33 PM
NXTFAZE's Avatar
NXTFAZE
NOt real sure....my low engine light came on, but it was because i was low and burning oil.....my h/c package is burning some oil which is to be expected....you may have a small leak??? check your parking spot or garage....
good luck
Old Oct 4, 2004 | 06:56 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
I was told (by a mechanic who knows Vettes) that sometimes it takes 4-5 start cycles to re-set this. It happened to me once...I started the car 4 times before the msg disappeared.
Old Oct 4, 2004 | 07:49 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
was a qt. low after driving 1300 miles from houston to ohio. filled to proper level and msg went away
To Low oil level
