In the LOop
Old Oct 5, 2004 | 01:32 PM
Irish Whiskey's Avatar
Irish Whiskey
Default In the LOop
What is a "drive shaft loop?" It is apparently used for dragging
Old Oct 5, 2004 | 01:48 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You are correct. NHRA required for certain brackets.
Here is an example of one vendors loop
http://www.corral.net/projects/deepf...shaftloop.html
Hope this helps.
Paul
Old Oct 5, 2004 | 01:49 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
i believe it is a loop that if something happened to the drive shaft it wouldnt come out from under the car. It is a safety product. It attaches to the frame of the car and it goes around the drive shaft to keep it in place. I have heard stories about broken driveshafts being like a pole vault for a car back in the day. and I have heard other stories about the drive shft hitting the ground and coming up through the floor and tearing up peoples legs
Old Oct 5, 2004 | 02:26 PM
G-lock's Avatar
G-lock
If you have a C5 your car came from the factory with all the driveshaft loop you'll ever need, it's called a torque tube . Jeff
Old Oct 5, 2004 | 02:39 PM
spiral04vette's Avatar
spiral04vette
From: Los Angeles I'm here for a good time, not a long time!
I love this forum, I learn something new about 5 times a day! Thank you.
Old Oct 5, 2004 | 02:45 PM
NSTG8R's Avatar
NSTG8R
yeh, that's what i was thinking .. and there's a metal plate over the toque tube anyways.
Old Oct 5, 2004 | 05:14 PM
If you race the car, it is a metal loop that fits around the drive shaft that prevents it from dropping to the ground in the event of breakage. Its basically a safety feature.
Old Oct 5, 2004 | 06:12 PM
BHP's Avatar
BHP
We used to call them "hoops." Was standard drag equipment on Mustangs since the old 9" rears used to snap pinion shafts.
The 'Vette is a different animal...
Old Oct 5, 2004 | 06:24 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
Very standard equipment on older high horsepower high tourqe drag cars. Nice added saftey net
To In the LOop
