Active Handling - Balancer - Rack Question????
Old Oct 6, 2004 | 12:06 AM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Default Active Handling - Balancer - Rack Question????
Why is it that when I had harmonic balancer changed on 99 C5 that I have Active Handing warming up and service soon light on DTC. Mechanic took the rack out of frame & this problem started at same time. Is there something amiss?? we are overlooking as everthing is plugged back up!
Old Oct 6, 2004 | 12:40 AM
Bill Dearborn's Avatar
Bill Dearborn
Does your mechanic know anything about C5s? I would check the steering wheel position before anything else. When the rack is out it is easy to get the steering wheel turned. To the eye it will look OK but to the steering wheel position sensor it will be 360 degrees out. The ABS, Traction Control and Active Handling all depend on the steering wheel position sensor.
Bill
Old Oct 6, 2004 | 01:11 AM
DragMan's Avatar
DragMan
Thats what I told him I thought steering wheel was not lined up right. How can I fix that or see if it is lined up right??
Old Oct 6, 2004 | 02:29 AM
CubanMissile's Avatar
CubanMissile
Does it shudder and traction breaks loose very easily now if you step on it? I will try to find the answer this morning.
Old Oct 6, 2004 | 11:26 AM
DragMan's Avatar
DragMan
not really, traction control works. Sometimes I feel the brakes appling and have to turn off traction control.
To Active Handling - Balancer - Rack Question????
