Passenger side PW not working
Old Oct 6, 2004 | 06:37 AM
Patman's Avatar
Patman
Default Passenger side PW not working
The other day I went to roll down my passenger side window and nothing happened. If I try the switch on the window itself, or on the driver's side, it's the same result.
But yet the window rolled up and down quickly before this point, the motor showed no signs of it being strained. I know in the f-bodies that the window motors start working much slower just before they die.
So based on this info, could it be something simple like a fuse or some connection which has come loose? The window worked fine on Tuesday (the last time I remember it rolling down) but by Friday it did not work.
Old Oct 6, 2004 | 07:58 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It's more likely the regulator for the window itself. When I bought my 97 2 years ago the passenger window didn't work. The dealer took care of it for me. It would be worth checking the fuses and the connector in the accordian like tube between the door and the body...but I'd bet it's the regulator. I'm sure others will chime in with some additional suggestions.
Paul
Old Oct 6, 2004 | 08:41 AM
roscoe118's Avatar
roscoe118
It's one of the common failures with these cars
Old Oct 6, 2004 | 09:17 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Same thing on our 98. It was the regulator.
Old Oct 6, 2004 | 09:50 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I agree with the above. Keep us posted on what you find.
Old Oct 7, 2004 | 06:39 AM
Patman's Avatar
Patman
How much does the regulator cost and how many hours of labor does it take to replace? (it's not something I would do myself, I'd get a dealer or a friend to tackle it for me)
Old Oct 7, 2004 | 07:48 AM
talon90's Avatar
talon90
NCM Ambassador
I don't know the cost for the replacement. I'm looking for my paper work but mine was replaced by the selling dealer under warranty and I don't recall the cost. To give you an idea, here is a link to the part in the Ecklers catalog. I tried to check with GMpartsdirect.com but the site is acting up. Hope this helps.
Paul
http://www.ecklers.com/product.asp?p...JMHVFRATGHFVFE
To Passenger side PW not working
