Painting Rotors
Old Oct 6, 2004 | 11:03 AM
mechanix19's Avatar
mechanix19
Default Painting Rotors
I just bought some new drilled and slotted rotors. I'm going to paint the center of them black to add a little touch. Anyone have any suggestions to how many coats of high temp paint I should use?
Old Oct 6, 2004 | 11:11 AM
stingray4me's Avatar
stingray4me
I just painted my calipers red the other day & used 2 coats.
Old Oct 6, 2004 | 11:50 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I just did mine red a couple of weeks ago. It took not quite 3 complete coats for me to be satisfied. You may get away with less using black.
Paul
Old Oct 6, 2004 | 01:25 PM
I'd say you could get buy with probably two coats.
Old Oct 6, 2004 | 01:43 PM
1EvilC5's Avatar
1EvilC5
St. Jude Donor '09
I would reccomend 2 - 3 coats. You would see rust on them with just one coat.
Old Oct 6, 2004 | 02:02 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
He said Rotors, not calipers./.
Old Oct 6, 2004 | 03:01 PM
Red Rag Top's Avatar
Red Rag Top
I put two coats of high temp flat black grill paint on the hub centers. Still looks good after 13 months
Old Oct 6, 2004 | 05:35 PM
TheHammer's Avatar
TheHammer
Old Oct 6, 2004 | 05:39 PM
3318C5's Avatar
3318C5
I used three coats..........
Old Oct 6, 2004 | 07:30 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I painted mine Chrome from Dupli-Color. So as to make them look like zinc coating. Worked well I get lots of compliments on them. They make the wheels look better than with the black. Two coats did it for me. Once the heat hit them they turned more grey than chrome but still better than the black. My .02
Old Oct 6, 2004 | 10:16 PM
VetteMan4Life's Avatar
VetteMan4Life
Can some one tell me the steps to painting my calipers, or point me in the right direction? I want the calipers red, so should i try it on my own or just buy the Z06 calipers?
Thanks,
Joe
Old Oct 7, 2004 | 06:33 AM
talon90's Avatar
talon90
NCM Ambassador
Vetteman,
There are several ways to go about painting your calipers. I left mine on the car and brushed on a caliper paint. Others have taken the calipers off and sprayed them (some have left them on and sprayed them). You can check out this thread I started with a link to some pics of my work.
http://forums.corvetteforum.com/showthread.php?t=912458
Further down the thread is a message with the type and color paint that I used. Hope this helps. It really isn't hard to do, and a lot cheaper (and easier) than replacing the calipers with the Z06. Go for it, you can do it!
Paul
Old Oct 7, 2004 | 08:58 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Yup, two coats did the job.
Old Oct 7, 2004 | 10:00 AM
MVP's Avatar
MVP
Mine already rusted and now I am thinking of painting. How would I go about getting the rust off?
To Painting Rotors
