[Z06] Which Optima Battery for Z06
Old Oct 7, 2004 | 08:54 AM
72Shark's Avatar
72Shark
Default Which Optima Battery for Z06
Which Red Top Optima batter is the correct part number for a Z06? My original Delco is petering out, and I would like to get an Optima today. Couldn't find any part numbers using the "search" feature. THanks!
Old Oct 7, 2004 | 10:50 AM
SupraEater's Avatar
SupraEater
it is part #84756947kjbt89469476kkfjkrj84944n
j/k
i am not sure if optima has part #'s??? i thought that it was one type of battery size and you either chose the red top or the yellow top. might be wrong though, but the last time i bought one that was what i was told.
Old Oct 7, 2004 | 11:11 AM
72Shark's Avatar
72Shark
I was wondering about that! IF that is the case, RED it is. THanks!
Old Oct 7, 2004 | 11:42 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Shark, either the "75" size or the "78" size will work; the 78 is physically bigger and provides a bit more juice (depending on your needs). The yellow top is a deep discharge battery; you probably don't need it unless you play a zillion watt stereo system for hours on end at your local cruise-in. Optima has a little battery holddown clamp or "foot" to replace the stock piece which holds the battery down; you may find it useful to provide a bit more clamping surface area.
Old Oct 7, 2004 | 12:04 PM
JimmyZ06's Avatar
JimmyZ06
I think it's 75 red top?
Old Oct 7, 2004 | 01:03 PM
RoHo's Avatar
RoHo
Default Optima
The direct replacement for my Z06 is a 34/78 series Red Top Optima Battery, every thing will fit the same as the stock one, But make sure you get the correct Optima hold down that has a radius in the hold down that will wrap around the center cylinder of the battery.
To Which Optima Battery for Z06
