Fix-a-flat woes
Old Oct 8, 2004 | 10:01 AM
Trigger Creep's Avatar
Trigger Creep
I Forget
Default Fix-a-flat woes
Despite my warnings, a friend used a can of fix-a-flat goo to repair a low tire after the Eureka Springs show last weekend. His DIC read XXX immediately for the tire pressure. One pressure sensor - R.I.P.
I resisted the requisite "I told you so". Now he's asking me if it can be cleaned, etc. I searched here, but couldn't find any info.
Is it a lost cause?
Old Oct 8, 2004 | 10:02 AM
jrose7004's Avatar
jrose7004
I wouldn't know but I'll bet you're right!
Old Oct 8, 2004 | 10:26 AM
AFVETTE's Avatar
AFVETTE
Aside from venting the tire refilling and repeating a few times in hopes the sensor clears itself I fear the sensor is ruined. If it's a 01 or newer the sensors can be purchased for about $60 and installed w/o removing the tire. You'll need a strong magnet to jump start it. But if he's luck he can repair this for less than $70 on hos own.
I added the LTPS to my Z and bought a 5th sensor in case I'm forced to use the goop.
Good luck
Tom
Old Oct 8, 2004 | 10:28 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I am afraid it is ruined. Even if for some strange reason the TS decides to wake up, it will never work correctly in giving you the readings.
Old Oct 8, 2004 | 10:33 AM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Time for a new sensor. Tell your friend to get a portable compressor & a tire guage.
Old Oct 8, 2004 | 11:12 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've been told the Fix-a-flat wrecks the TPS. Nericreations sells and repairs TPS for '97 - '00 cars. Sounds like a repair or a replacement is next on the agenda......
http://www.nericreations.com
Old Oct 8, 2004 | 12:15 PM
BHP's Avatar
BHP
Interesting. How do you remove the sensor without removing the tire??? Please explain, thanks.
Old Oct 8, 2004 | 12:48 PM
Afraid it is toast. Time for a new sensor.
Old Oct 8, 2004 | 07:00 PM
leaftye's Avatar
leaftye
I'm an Air Force programmer (3c072) and when I demonstrate my computer skills, I attribute my success to "magic", but I'd like to know how AFVette changes his sensors without removing the tire too!
Old Oct 8, 2004 | 11:56 PM
murphman72's Avatar
murphman72
Is it a lost cause?
I picked up a roofing nail while driving through the Cross Bronx Expressway in New York and in a moment of desperation used Fix A Flat. I was on my way back to Maryland. The sensor did not go out until about 2 weeks later. Mind you that the dealership did a tire repair in between. My car is an 04. So the new sensor was installed under warranty. If you still have a warranty, see if it can be repaired through that.
The oddity of this was that the error codes appeared about a week after the dealer "repaired" the tire.
To Fix-a-flat woes
