Switched Power Lead?
Old Oct 9, 2004 | 09:25 PM
georgec114's Avatar
georgec114
Default Switched Power Lead?
My 01 had a nice little aux power plug under the the pass. side
floor. But apparently sometime after that, GM eliminated it.
My 04 doesn't have it.
Has anyone found a nice switched power line for the radar detector?
...George
Old Oct 10, 2004 | 05:21 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I think this may be your only option.....
http://forums.corvetteforum.com/show...entine+install
Old Oct 11, 2004 | 12:06 PM
SLWRNU's Avatar
SLWRNU
Default Radar Detector
...George
Answered this before but here goes. In my 04 just installed the V1.
Go to Auto Zone. Pick up the mini add-a-circuit. Remove the pass side floor panel (easy). Remove fuse cover and look for a blank fuse outlet that has power only with the ign on. Plug in the add-a-circuit and 10 amp fuse (supplied). Wire your unit's power line into the wire protruding from the add-a-circuit and ground the unit. remove the pass side kick panel and snake the unit wire up through windshield pillar (use a small blade screwdriver and pry slightly). You're done. Very easy and takes about 30 minutes. Good Luck.
To Switched Power Lead?
