Convertible Antenna Disable
Old Oct 10, 2004 | 08:53 PM
Vettman 1's Avatar
Vettman 1
Default Convertible Antenna Disable
I bought XM radio so don't need the antenna going up and down everytime the ignition is turned on. Does anyone know the easiest was to disable? Perhaps a fuse, or location of the connector?
Old Oct 10, 2004 | 09:09 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
If I'm not mistaken you can take the back panel out in the pass. side cargo and cut the pink wire. I think I saw a thread were someone put a switch on it so it would only go up when they wanted it to
Old Oct 10, 2004 | 09:14 PM
GrayC5's Avatar
GrayC5
I've never tried it, but several aftermarket and Forum vendors here carry something similar to this: Power Antenna Bypass Harness.
Old Oct 10, 2004 | 09:15 PM
1KLRTOY's Avatar
1KLRTOY
Just put a switch in the pink wire, I put my switch in place of the ashtray
Old Oct 10, 2004 | 10:54 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Yep, I did the same thing. I accessed the pink wire in the trunk located by the antenna motor and then ran wires under the carpet to the center console. I put a radio shack soft push (Looks like a nitro button) in the piece that holds the traction control button. I listen to CD's most of the time so my antenna stays down unless I hit my $3 button. Have fun.
Jim
Old Oct 11, 2004 | 12:44 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I've been thinking of doing the same thing. I only listen to CD's also. Corpsvette do you have pictures of your install?
To Convertible Antenna Disable
