Headlight Override
Old Oct 12, 2004 | 05:53 PM
marksr's Avatar
marksr
Default Headlight Override
In my older Vette's, there was an driver compartment override to allow the headlights to stay open, but turned off. This was great for cleaning, waxing, and when stuck in freezing rain conditions so they didn't get frozen shut.
Is there a similar feature on the '04 C5? I haven't found it if there is.
Old Oct 12, 2004 | 05:54 PM
wireless's Avatar
wireless
Photochop Terrorist
Turn them on then click back one. Or you can manually raise them with the *****. They're covered by a rubber boot that even tells you that you can raise them manually.
Old Oct 12, 2004 | 05:57 PM
srchief100's Avatar
srchief100
Use the manual ***** to raise them. They are covered with a rubber dust boot just to the inside of each light.
Old Oct 12, 2004 | 06:05 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yep, both of these will work.
Paul
Old Oct 12, 2004 | 06:14 PM
marksr's Avatar
marksr
I am sure these both will work. For the one click back method, it still leaves your parking lights on and if you remove the key and exit you get the lights on alarm and a dead battery after a while.
Does anyone know of a mod to install a switch to override the electric motor?
Old Oct 12, 2004 | 06:33 PM
talon90's Avatar
talon90
NCM Ambassador
Yep, that's a good point. I think we all focused on the cleaning/waxing part of your post and not the "Stuck in freezing weather" part. I've had other cars that allow this, but I'm not aware of anything for the Corvette, just the manual crank em up method. No bell, no dead battery, just a few dozen turns of the *** per side : Hopefully someone else will have some ideas.
Paul
To Headlight Override
