Today while driving with a very low gas tank, I got the message "remove key and wait 10 seconds." I was in the middle of an intersection, so I humbled along (with no power whatsoever) until I could pull over, shut down, remove key, etc. When I restarted, everything was fine.
You can find even more threads using the Forum search feature, especially if you search on words such as column lock or column lock recall.
Good luck!
I didn't go through all of the threads you listed, but I've never heard of an exact situation like he has, where the car has been driven for a while and some association with low fuel.
The driver provided the low fuel info, the car ided the error condition which was unrelated to the low fuel situation. Next!
Correct. But he said "Today while driving with a very low gas tank, I got the message "remove key and wait 10 seconds." I was in the middle of an intersection".
Even without the 'low gas' comment, he said he was driving. He didn't say the car died. Maybe he can clear up that point. Otherwise, it's the same only different.
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
What was that all about?
Never heard that one before
maybe it is another way that the car is say fill the tank or you will pushing soon
Sounds like someone who has had the recall "fix" performed and then got bit anyway....they re-flashed the computer and now when the dreaded CL occurs your fuel gets cut off.....sweet fix GM....
That reminds me...need to run to the mailbox and see if my refund check is there for my CLB....Thanks GM
It did happen for my 01 vette long time a go like 3 times and dident come back but wats really is going to let you go thats after like the 3 times the steering wheel locked on me when i was driving and the car turned off it was bad i dont know if thats from that masseg or not i dont really know but they came all in the same time
