Battery Tender - Voltage?
Old Oct 13, 2004 | 11:56 AM
vettenovice's Avatar
vettenovice
Default Battery Tender - Voltage?
I went on-line to buy a Battery Tender Plus. What voltage do I buy for a 2001 vette?
Thanks.
Old Oct 13, 2004 | 11:57 AM
jerrymcb's Avatar
jerrymcb
12 Volt
Old Oct 13, 2004 | 11:58 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by jerrymcb
12 Volt
Old Oct 13, 2004 | 11:59 AM
sharpvet03's Avatar
sharpvet03
12 Volt
Did you mean amp?
Old Oct 13, 2004 | 12:23 PM
vettenovice
OK. I see that 12V units come with a choice of amperage. What amperage do I need?
Thanks again.
Old Oct 13, 2004 | 12:56 PM
ersatz928's Avatar
ersatz928
Either size Battery Tender will do fine, the smaller current rated unit will just take longer to charge a partially discharged battery.
Old Oct 13, 2004 | 01:00 PM
sharpvet03's Avatar
sharpvet03
I have a 1.5 amp. with auto shutoff,make sure that it is auto shutoff or you will fry it.
Old Oct 13, 2004 | 01:22 PM
I have a Sears DieHard Battery Maintainer - cost about $30 and works very well. It has an auto shutoff feature.
Old Oct 13, 2004 | 01:26 PM
JC in XTC5's Avatar
JC in XTC5
The Battery Tender Plus is what you need (12V).
Old Oct 13, 2004 | 01:40 PM
jerrymcb's Avatar
jerrymcb
Or a VDC Electronics Battery Minder. You can leave either of these
on indefinately with no fear of battery damage.
To Battery Tender - Voltage?
