z06 vs coupe
Old Oct 15, 2004 | 12:18 AM
gmosley's Avatar
gmosley
Default z06 vs coupe
are a c5 coupe and z06 the same sixe as far as cabin room inside the car mainly the trunk area
my uncle just bought a z06 as i will be getting a coupe but i wanted to get a jump on building the sub box for my coupe and was wondering if i could use the measurements from the z06 in a coupe with no problems other than the area where the roof panel goes
Old Oct 15, 2004 | 12:12 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
they are two totally different animals... I would wait until you can get measurements of a coupe before you do anything.
Old Oct 15, 2004 | 12:18 PM
BigJoe's Avatar
BigJoe
If you are going to fit it down into the floor wells somehow, they will be the same, but just about everything else will be different.
Old Oct 15, 2004 | 01:05 PM
I do not believe they are. Maybe you could find someone who has a coupe and ask them if you could look at the trunk area and take some measurements. Explain what you are doing and they hopefully will help you out. Otherwise, go test drive a coupe and while you have it, do your measuring.
To z06 vs coupe
