door sill seals
Old Oct 15, 2004 | 11:24 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
Default door sill seals
Has anyone tried the door seals that the catalogs sell?
http://www.madvet.com/shop?frame=1.53.44
I drive my car down a half mile of gravel and the inside of the car just gets nasty... by the time I make it to the end of the road you can see the gravel dust hanging in the air in the car.
do these things really seal the doors well?
Old Oct 15, 2004 | 11:34 AM
BigJoe's Avatar
BigJoe
They only seal the bottom, but most of the stuff (water, dust, etc) comes from above. The path for water actually runs down the door jamb and out the outside sill under the door. To stop it all you'd have to seal off the entire door.
Old Oct 15, 2004 | 11:50 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
this is a no win mod... Ive yet to see anyone say they do what they are suppose to do... you will still get water on the sill and you will still have to clean them..
Old Oct 15, 2004 | 12:08 PM
GR8-LIFE's Avatar
GR8-LIFE
I had a chance to get these when I was at Ecklers 2 weeks ago but I forgot. Glad I'm reading this thread.
Old Oct 15, 2004 | 12:09 PM
bsmith's Avatar
bsmith
I am not worried about the water getting on the sills... I would be happy if it just cut down on the amount of dust entering the car.
Old Oct 15, 2004 | 12:38 PM
leonm47's Avatar
leonm47
I have them on my CE and had them on my 99 Coupe they work great for me and keep quite a bit of the garbage out of my sills. I 'm glad I got them.
Old Oct 15, 2004 | 12:47 PM
I doubt that the item you are looking at will help keep the dust out. Mid-America sells another item called a Cowl Vent Filter (Part number 603-829) that is designed to keep dust down. Have not used it, but that is what it says it does. May want to check it out.
Old Oct 15, 2004 | 01:55 PM
ma2kz06's Avatar
ma2kz06
If you do get them you will need to keep rubber very clean. A friend of mine put them on his car. He was not diligent about keeping the rubber clean and the sand that started to attach itself to the seal eventually started scratching the sill. He ended up removing them because they were just as bad to keep clean and he had to get his sill repainted to fix the damage they caused.
I would say don't do it but good luck in what ever you decide.
To door sill seals
