Cruise Control Not Working
Old Oct 15, 2004 | 08:56 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Cruise Control Not Working
After almost 5 years, I tried to set the cruise control coming back from palm Springs. It would not set, got out the book, no help. I am assuming it could have come from the factory inoperative, anyone else experience this??????? Just a feature I really don't care that much for, but since its there, I want it to work.
Old Oct 15, 2004 | 08:59 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
No.
Old Oct 15, 2004 | 09:35 PM
Lowcash's Avatar
Lowcash
I have had mine disengage and not re-engage while driving. If I slide my foot behind the brake and pull it towards me I am able to re-engage the cruise control.
Apparently there is a 'pin' behind the brake pedal that disengages the cruise control.
Other than that I have no idea.
Old Oct 15, 2004 | 10:42 PM
CipVette97's Avatar
CipVette97
Mine seems to have stopped working recently as well. Hmmmm....
Jeff
Old Oct 15, 2004 | 11:47 PM
Admiral Fairway's Avatar
Admiral Fairway
I was having the same problem on my '97, what I had to do was put my foot under the brake pedal and lift up on it a little. After I got tired of doing this I climbed under the dash and adjusted the stop light switch, this solved the problem.
Old Oct 30, 2004 | 07:28 PM
582Boat's Avatar
582Boat
My 99 Vette discontinued working, made an appointment with the dealership to have my Airconditioner tensioner replaced and while on the way to the shop was stopped by the local police for not having any tail lights. Told the dealer to fix the tail lights and was told that was why my cruise did not work. Check it out. Doc
Old Oct 30, 2004 | 10:28 PM
Thankfully, mine has always worked just fine. Could be the switch, the unit itself, a fuse (not sure if there is a single fuse that controls the cruise or not), or perhaps something else. Good luck getting it solved.
Old Oct 31, 2004 | 01:09 AM
Shortimer's Avatar
Shortimer
When I got my '01 in Oct. of 2003 the cruise control did not work. I had the car about a week before I tried to use it. It was repaired under warranty. The problem with my cruise control was a bent pin in the wire harness. Hope this helps.
Old Oct 31, 2004 | 01:21 AM
StevieB's Avatar
StevieB
Jeff
Me too
Old Oct 31, 2004 | 01:32 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Mine stop working once when my knee hit the key shuting off the car while driving. When I restarted the car, the cruise control would not work until I stopped removed the key and restarted the car.
hope you find the problem
Old Oct 31, 2004 | 11:03 AM
Grand Slam's Avatar
Grand Slam
When mine failed GM initially adjusted something but it failed again. The second time they replaced a microswitch behind the clutch pedal which fixed it. Other's have mentioned the brake pedal microswitch. It could a number of things.
Old Oct 31, 2004 | 04:54 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I have 13 months left on the extended warranty, off to the dealer after New Years.
Old Oct 31, 2004 | 04:59 PM
PaceThis's Avatar
PaceThis
As mentioned, it's quite common that it's just a tail lamp, so you might check that before scooting to the dealer. Most vehicles are designed to make the Cruise inoperative when a tail light goes out. That way you'll take it in to see what's wrong with your cruise even if you didn't notice that your tail light was out...they figured that was the quickest way to keep your safety equipment working...
Old Oct 31, 2004 | 05:14 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Thats not it, just went out to the garage to check the tail light, all is well.
Old Oct 31, 2004 | 06:59 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
AL....did you check the fuse panel in the footwell on the passenger side?
The lid is labeled as to what fuse is what.
To Cruise Control Not Working
