I have a 99 FRC. If I turn the t/c off does it disengage my anti-lock brakes also? And I have read about this competitive mode. I dont think my car has this, can you advise? I have held it down till my finger was numb and it just stays off. Thanks
No it won't turn of your anti-lock brakes. Not sure on the competitive mode. I don't remember what year it came out as an option. I know my 97 doesn't have it. I thought that it was 98 but someone else better informed should answer. Just try pressing and holding the T/C button down for several seconds while stopped and see if the DIC returns a COMP MODE message.
I have a '99 FRC as well and it does have active handling. I believe all FRC's came standard with active handling.
Turning off the active handling or traction control does not effect the anti-lock brakes. To put it into competitive driving mode you must be stopped and hold the button down for several seconds. The DIC will then tell you when you are in competitive driving mode.
Active Handling was an option until 2001 on all Corvettes. I'm pretty sure the FRCs did not have it in 99.
Since we will probably be running against each other on a track again, you should also leave your traction control, emergency brake, and air conditioner on and start in reverse.
Mine is a 99. It has it DIC will show "COMPETITION MODE" after a few seconds of holding down the button, and yes, mine has always been stopped when engaged.
Originally Posted by '99 Feather
I have a '99 FRC as well. I believe all FRC's came with active handling.
No they didn't. TC only on mine. Either way, I agree with your comment regarding ABS. Neither TC nor AH has anything to do with disabling ABS.
BTW folks, GM does not print a separate owner's manual for each model of Vette. Usually there is a statement in the various sections to the effect of "if applicable".
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
According to the Corvette Black Book - AH/TC (RPO JL4) was optional on the FRC in 1999. Real-Time Selective Damping (RPO F45) was NOT available on the FRC.
I believe TC was standard equipment on all C5's since 1997.
As Glenn said - Comp mode turns off TC only, leaves AH engaged and nothing shuts off ABS.
Why does my owners manual explain how to access competitive driving mode and what it is to be used for? Mine is a 99 Coupe.
You ask "Why does my owners manual explain how to access competitive driving mode"
To be quite honest, for the same reason your manual tells you how to open your hood, or how to use you windshield washers, etc, etc.... I apparently do not understand your reason for asking that.
As for what it's used for? The link I supplied in my previous reply to this post will tell you that in some detail. Check it out.
