Window Module - Please help
Old Oct 16, 2004 | 10:50 AM
mikej1957's Avatar
mikej1957
Default Window Module - Please help
I have a bad passenger side window module on my 99. Can anyone offer advice or help on changing this? Pictures and descriptions are great.....
thanks
Mike
Old Oct 16, 2004 | 06:03 PM
markcz's Avatar
markcz
Click here for illustrated instructions to take the door apart.
Exactly which piece do you mean by 'window module', I can look up the part number (if you need it) with a more detailed description.
Old Oct 22, 2004 | 08:16 AM
mikej1957's Avatar
mikej1957
I mean the power modult that controls the window, mirror, and door lock... passenger side.....
thakns for instruction
Old Oct 22, 2004 | 07:00 PM
markcz's Avatar
markcz
From Gmpartsdirect.com
GM PART # 9352891
CATEGORY: Keyless Entry Fobs & Batteries
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $259.75
OUR PRICE: $148.05
DESCRIPTION: MOD-F/CON
Unless you're sure it's the control module, another possibility (depending on your symptoms) is a broken wire in the accordian looking tube at the front end of the door. Just FYI before you spend the $.
Old Oct 22, 2004 | 07:15 PM
mikej1957's Avatar
mikej1957
Default Power window module
I took it to the dealer at the insistence of GM Customer NO Service.... I have replaced both regulators, headlight motor, A/C blower, wiper motor, and two recalls on steering column,,,, too many electrical problems. After I paid for the diagnostic fee, of course there was no help from GM as they had implied. They said it was shorted out. Door locks and mirror do not work either. I am goign to assume this is the problem.... unless you have other ideas.....
Thanks again...
BTW I hjave been trying to get a price from GM PArts direct for a week with no luck at all
Old Oct 23, 2004 | 07:01 AM
markcz's Avatar
markcz
It just may be a bad module, but I'd try to rule out the simpler and less expensive possibilities before buying a new one.
Here are the schematics for the passenger side door: page 1, page 2
I'd start by checking fuses 30 and 31. Swap them out with known good fuses.
Once you know the fuses are good try this. Open the door half way, take the door panel off (leave the switch connected), pull back the accordian cover over the wires, then hold down a button or two and tug/pull/poke/push/wiggle the wires and connectors to see if anything happens. If you get any movement from something electrical then you just have a broken wire somewhere.
If that doesn't work, or even if it does, take the plugs off of the control module and check to verify that you have + and - voltage where you should have it. You can use any $10 multimeter to check the pins on the end of the connectors. Look at this page for C1 C2 C3 and this page for C4 to see the connector end views.
C1 is the big red plug, you should have +12V on the top right pin with the orange wire, and -12V (ground) on pins 6 and 14 which are both black wires with white stripes. Use the links to check out C1 and to see where C2, C3, and C4 should have power. Send me an email if you need instructions on how to use the multimeter to check for voltage.
If you go through all of that and find 12V everywhere it should be, then the problem is most likely the module If you get really desperate you can drive over to Augusta on one of my days off and I'll help you out.
Let us know how it goes.
To Window Module - Please help
