Detecting a CLB (new question!)
Old Oct 18, 2004 | 05:16 PM
vettenovice's Avatar
vettenovice
Default Detecting a CLB (new question!)
Before I go and buy the CLB, is there an easy way to tell if the car already has one without having to take off the knee wall? I was thinking maybe doing something with the DIC?
Old Oct 18, 2004 | 05:34 PM
Patches's Avatar
Patches
If you can turn the wheel with the key out of the ignition (obviously with the car off) and you have an MN6 then you have the CLB. If you can do the same but have an A4, then you either have the CLB or your car had the recall done which disables the CL. Either way, you're good to go because you no longer have a locking column.
Old Oct 18, 2004 | 05:42 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
Easiest way to check!
Old Oct 18, 2004 | 05:46 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
With the key out of the ignition, simply see if the steering wheel turns. If it turns, you have one of the following:
1. A 2001 or newer A4 (no CLB needed)
2. A 1997 to 2000 A4 w/ the GM recall fix performed to it or a CLB installed.
3. Any year 6 speed w/ a CLB installed.
Old Oct 18, 2004 | 05:52 PM
Patches's Avatar
Patches
Good one, BiggieBoy. Forgot the "Factory CLB" for the later A4's.
Old Oct 18, 2004 | 07:13 PM
BiggieBoy's Avatar
BiggieBoy
Old Oct 18, 2004 | 07:31 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
If you want to verify whether the recall has been done for an A4 (1997-2000) or if a CLB is installed you may have to pull the knee bolster if you do not have documentation on the recall. Otherwise, as all above have said if you can move the steering wheel without the key, the column lock has been disabled. Let us know what you find out.
Old Oct 18, 2004 | 08:06 PM
Blue Lion's Avatar
Blue Lion
The method suggested worked for me. Give it a try.
Old Oct 18, 2004 | 09:10 PM
xilr8n's Avatar
xilr8n
turn off key and extract it. whirrrrrrclick = potential problem
Old Oct 18, 2004 | 09:53 PM
Tally Ho's Avatar
Tally Ho
Not necessarily. I've had the recall done and the whirrrrclick noise still occurs occasionally. The column however does not lock. My car is a 98 A4.
Old Oct 18, 2004 | 10:02 PM
jeff1surfs's Avatar
jeff1surfs
Default bomb waiting to go off!
My CLB has been ordered....man hope it gets here soon
I hate that noise every time I hear it
Old Oct 19, 2004 | 01:06 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
if you had a CLB... you wouldnt hear that noise
do yourself a favor and get one now... especially if you hear the noise occasionally
Old Oct 19, 2004 | 02:13 AM
Sebring_C5's Avatar
Sebring_C5
Yep, if there is no CLB then you will hear a "zzzt" noise when the key is taken out. After the CLB there is just a faint "click" sound.
Old Oct 19, 2004 | 12:27 PM
Rob4092xx's Avatar
Rob4092xx
I have a 2000 with an automatic.
I performed your "test" last night and the tires moved with no problem!
Boy, am I relieved!
Thanks for the tip!
Old Oct 19, 2004 | 12:39 PM
If you have the manual and the column still locks without the key in the ignition, get the CLB. It will prevent problems down the road.
Old Oct 19, 2004 | 01:03 PM
Theothergy's Avatar
Theothergy
Default Well, I don't have ??
Can anyone suggest the best place to purchase the bypass??
Sounds like I need to act quickly on this ..
Old Oct 19, 2004 | 01:05 PM
sharpvet03's Avatar
sharpvet03
To Detecting a CLB (new question!)
