Battery size?
Old Oct 19, 2004 | 02:30 PM
Fast one's Avatar
Fast one
Default Battery size?
What size battery fits a C5 and has anyone bought an Exide Orbital battery? Also what CCA is needed?
Old Oct 19, 2004 | 03:23 PM
Sportsdude's Avatar
Sportsdude
Not sure but I just ordered Optima Red 75 for my car.
Old Oct 19, 2004 | 04:02 PM
Cochemarman's Avatar
Cochemarman
I've got an excide orbital 'Maxxima' battery. Had no choice, you can't get red tops this side of the pond. But as the markings and ratings on it seem to be identical to the red top I do think that it maight be the same battery with a different outer package.
I'd go and look at it right now for the model number, but it's dark here.
The CCA was 800, 900 at zero degrees C.
It works brilliantly.
Bet they're cheaper where you are (even thought they're made in Spain)
Old Oct 19, 2004 | 05:32 PM
Not sure about the Exide battery size, but in the Optima, I have a 34/78 Red Top. Works just fine.
Old Oct 19, 2004 | 05:42 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I have the same one. The ratings on the 34/78 are; CA 980 & CCA 800
Old Oct 20, 2004 | 03:34 AM
Cochemarman
Just checked under the bonnet.
The battery is an Exide Maxxima 800 34/78 Orbital Technology.
Basically the same as the red top only not red.
Old Oct 20, 2004 | 04:19 AM
Rickk's Avatar
Rickk
I have an Optima Redtop,,,,, 34/78 800CCA... You really don't need that much. I think my original AC/Delco was 600CCA.
To Battery size?
