Soft Clutch? Please help!
Old Oct 20, 2004 | 12:21 PM
CCND4SPD's Avatar
CCND4SPD
Default Soft Clutch? Please help!
I've been reading lots of post, but still not sure on a clear answer. My question is during the mornings it seems that the clutch is really soft but after driving it for awhile it will feel like it's back to normal. I've read people saying to change your clutch, bleed the hydraulic fluid, change the slave. I also read that some clutches have stuck to the ground. Is what I am experiencing an early sign that my clutch will stick to the ground? I don't have any problems with it sticking or do I have problems shifting. It shifts normal. If anyone can give a simple answer to this puzzling issue that I am having it will help greatly! Thanks in advance.
Christopher
Old Oct 20, 2004 | 12:32 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
I cant remember if you are the one that IM'd me about this or not... but have you checked the fluid level of the reservoir under the hood?
