"Corvette" Embroidery
Old Oct 23, 2004 | 05:32 PM
Lensboard's Avatar
Lensboard
Default "Corvette" Embroidery
I am sure it has been discussed before, and probably at length, but how do I get the word "Corvette" on my seats to stop fraying? ...Seat covers??
Old Oct 23, 2004 | 05:54 PM
Not sure how you can stop it if it is unraveling. However, you may want to see if Ken King at Vette Essentials can give you some suggestions. Seat covers may help.
Old Oct 23, 2004 | 08:19 PM
Lensboard's Avatar
Lensboard
Thanks, any one else can help?
Old Oct 24, 2004 | 12:47 AM
Lensboard's Avatar
Lensboard
ttt
still need suggestions
Old Oct 24, 2004 | 12:50 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
put some superglue (or some similar agent) on it to hold the stitching together?
Old Oct 24, 2004 | 12:58 AM
Lensboard's Avatar
Lensboard
Well, thanks for the suggestion, it is not coming apart, just fraying. I cut off some hanging strings, but it doesnt appear to be stopping. I can't be the only one with this problem...??
Old Oct 24, 2004 | 01:03 AM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
this may sound ridiculous but try hair spray or something similar. I know once my seats start to go, I will be driving over to see Ken King.
Old Oct 24, 2004 | 04:38 AM
bluemax1724's Avatar
bluemax1724
St. Jude Donor '06-'07
Try using a cigarette lighter. Use it in a brushing motion. If done corretly, only the frayed areas will be affected. We used this method when removing frayed areas on parachute cord, which was used for the captivation of tools, used during refueling operations aboard Nuclear Subs. Just don't hold it in one place toooooooooooooo long. I hope this helps. It worked great for those of us who used it. You might try it on a test piece of embroidery, if you have something like that available.
Good luck.
Old Oct 24, 2004 | 08:42 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
Good luck.
easy there...
...that was nylon...
...the threads are cloth...
I snipped until the fraying slowed...and ultimately...ceased...
seat covers will at least prevent damaging the embroidery further
Old Oct 24, 2004 | 10:21 AM
RCK1999's Avatar
RCK1999
Stop in a sewing store or sewing dept. of WM. There is a product called "fray-check" that will take care of the problem. Clip the frayed areas first. The other suggestions will tend to leave residue or make the repair look even more obvious. The "fray-check" solution will do the best job as it is thin and absorbed into the thread.
Old Oct 24, 2004 | 12:11 PM
Lensboard's Avatar
Lensboard
Best suggestion yet, thanks
Old Oct 24, 2004 | 01:25 PM
NSTG8R's Avatar
NSTG8R
well .. you are.
WHAT ARE YOU TALKING ABOUT!?
Old Oct 24, 2004 | 01:42 PM
Lensboard's Avatar
Lensboard
I will post some pics of my porblem.
Old Oct 24, 2004 | 03:23 PM
mlupone's Avatar
mlupone
Try a product found in most fabric stores called "Fray Check" made by Dritz.
As always, spot check before applying.
I haven't the problem as mentioned with my seats, but I've used it on a small area that was fraying on my convertible top.
Old Oct 24, 2004 | 07:50 PM
Lensboard's Avatar
Lensboard
Here is a photo of what I am talking about. I can't be the only one with this problem........can I?
Old Oct 24, 2004 | 08:29 PM
Lensboard's Avatar
Lensboard
ttt
Old Oct 24, 2004 | 11:34 PM
Lensboard's Avatar
Lensboard
Thanks for the input so far. I am looking for some advice from someone that has had this problem.
To "Corvette" Embroidery
Old Oct 25, 2004 | 10:20 PM
Lensboard's Avatar
Lensboard
I am still hoping to here from someone with this problem.
Old Oct 26, 2004 | 08:59 AM
StuzVette's Avatar
StuzVette
...well you said this was a good suggestion...
Have you tried any suggestions yet ?
Incidentally, mine did stop fraying...
1) snipped fraying threads...
2) I use Zaino leather treatment on my seats...I believe the lotion soaked threads are less likely to fray...Note: I didnt soak the threads I just dont avoid the threads when applying the leather treatment...
I also apply leather treatment each time I wash StuzVette...
...thus my embroidery has ceased unraveling...
Old Oct 26, 2004 | 10:49 AM
Ron71's Avatar
Ron71
I found a little clothes shaver at Walmart for about 5 bucks. (Those things that shave the fuzzies off of sweaters). I used it once to shave of the frayed ends and I haven't had a problem since.
