Can I shave the Dot matrix pattern
Old Oct 24, 2004 | 01:37 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default Can I shave the Dot matrix pattern
Can I shave the Dot matrix pattern on the back window before tinting?
I understand I'll have to be super careful not to destroy the rear window defroster...thinking a flat razor would do the trick???
Peace
Willfulone
__________________
..................Click for
Old Oct 24, 2004 | 01:41 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I think you'd be better off to paint around them instead. That's what I've heard several times that some of the better tint shops did.
Old Oct 24, 2004 | 01:51 PM
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
I've heard of people lightly sanding it but never heard of anyone using a razor blade on it.
Others have said that they were able to tint right over the dots with no problem. I think they just had to go back a few days after the tint was originally put and and just smooth everything back out again.
Old Oct 24, 2004 | 03:07 PM
vizkiz's Avatar
vizkiz
Threadkiller
Cruise-In 9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09
If you try using a flat razor, you'll probably scratch the window.
I prep new cars and have had to scrape glue off the inside of a window more than once, and haven't even scratched the dot pattern on the window with a little pressure. The amount of pressure you'd need with a flat razor would definately scratch the window.
Old Oct 24, 2004 | 03:10 PM
NSTG8R's Avatar
NSTG8R
Old Oct 24, 2004 | 10:06 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
As others have said, a razor is going to cause more problems. Read this description of what I had done to my coupe rear window:
http://forums.corvetteforum.com/show...post1548570750
To Can I shave the Dot matrix pattern
