oil life remaining question
Oct 24, 2004 | 11:54 PM
I just had the oil changed but the "Oil life remaining" on the DIC still shows 5%.
First, how do I reset the oil life remaining.
And second, would the check engine light come on because of this?
Oct 24, 2004 | 11:56 PM
CI 6-7, 9-10 Veteran
Look in your owners manual for this. If memory serves me correct, which it doesn't most of the time, Hold the reset button in for a few seconds.
Oct 25, 2004 | 12:03 AM
How to Reset the "Oil Life" indicator
After an oil change, you need to reset the oil life indicator so that you know when the next change is due. Here is how to do that:
1) Turn the ignition on, but make sure the engine is off.
2) Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage.
3) Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 100%" should appear on the display.
Oct 25, 2004 | 01:11 AM
Here is another way.
Turn on the ignition but don't start the car. Depress the gas pedal 4 times.
Oct 25, 2004 | 01:12 AM
Oct 25, 2004 | 02:14 AM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
This one works for me.
Oct 25, 2004 | 05:51 AM
Why would anyone bother doing it with the gas pedal method when all you need to do is hit the reset button?
Oct 25, 2004 | 06:55 AM
Follow the steps mentioned by GrayC5.
I would not think that your check engine light would be related to this.
Oct 25, 2004 | 10:21 AM
And all of that is contained in your fine manual!
Oct 25, 2004 | 05:21 PM
Check engine lights are usually related to emissions systems stuff....
-Mike
Oct 25, 2004 | 07:12 PM
I just reset my oil life for the first time and it didn't exactly work the way the manual said. When I held the reset button I got a xxxx oil life message rather than it saying " reset" like the manual said. After a few tries with the same response I turned off the ignition and when I restarted the oil lfe displayed 100%. Does it matter if you do this with the engine running or off?
Oct 25, 2004 | 07:39 PM
Thanks guys. It worked with the engine shut off. Doesn't work when engine is on. But the check light is on. Guess I gotta take her in.
I have no warranty. Any suggestions to where to go?
Oct 25, 2004 | 08:37 PM
St. Jude Contributor
No warrany? Read your codes through the DIC, and post them here to find out what they are. Sometimes, you can reset the computer, and the code will not come back. Example is a misfire code due to poor fuel, or the fuel cap not on all the way.
Oct 25, 2004 | 08:42 PM
Take a look at you codes first. Some can just be cleared.
http://www.stengel.net/diccodes.htm
Oct 25, 2004 | 08:43 PM
Quote:
Yes. Step 1 in the manual reads, "1) Turn the ignition on, but make sure the engine is off."
Oct 25, 2004 | 09:08 PM
DONE! But the check engine light is still on.
