High Flow Power Duct Install Question?????
Old Oct 25, 2004 | 08:35 PM
CN RED's Avatar
CN RED
Default High Flow Power Duct Install Question?????
I just installed a new Carbon Fiber Power Duct and I'm getting a "check engine" comes on. I reapllied the MAT sensor as directed by the instructions that came with the new Duct.
However there's a plug in sensor that has nothing to plug into on the new duck but has something to plug into on the stock one.....Could that be my problem?
Anyone that can assist me with this issue please chime in. I'll be out in the garage changing my oil and I'll check back in a few minutes or so.
Thanks in advance.
CN RED
Old Oct 25, 2004 | 08:39 PM
C5JONNY's Avatar
C5JONNY
Thats def. your problem, call the manufacturer and see what they suggest. You may have to drill a hole in the new one.
Old Oct 25, 2004 | 08:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You'll have to remove the IAT sensor from your old duct, drill the hole and install it into the new one, and reconnect it.
The unplugged sensor is likely what tripped your check engine light. Reinstall the sensor in the new duct, clear your codes, you should be all set.
Old Oct 25, 2004 | 08:49 PM
CN RED's Avatar
CN RED
Thanks just changed the oil and filter. I'll remove the sensor from the stock Duct and mount it to the new one. I'll keep you guys posted on the results.
Thanks again,
CN RED
To High Flow Power Duct Install Question?????
