Replacing fog lights - access
Old Oct 26, 2004 | 01:41 PM
Navy Blue's Avatar
0Navy Blue
Former Vendor
Default Replacing fog lights - access
Are the fog lights accessed thru the area where the Z06 screens are or by another method?
Old Oct 26, 2004 | 02:45 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
If you lift the hood.. and locate the front hood stops,( adjustable, silver in color with a black rubber stopper on top ) which are next to the headlights.. raise the headlight, remove the black plastic surround panel, and the hood stop.Removing the hood stop gives you a little extra room to get your arm down there. The fog light bracket is held in place with one 10 mm screw. the bracket has a centering locator clip on the top..
once the screw is removed, you can remove the bracket noting the locator tip on the top.. a quarter turn removes the bulb socket.
Old Oct 26, 2004 | 02:57 PM
Navy Blue's Avatar
0Navy Blue
Former Vendor
Thanks Evil-Twin.
Old Oct 26, 2004 | 05:38 PM
Do like Evil-Twin mentioned or go up from the bottom by taking off the lower panel on the front fascia. Easy to do if you have a floor jack, but going through the headlight area would be easier.
Old Oct 26, 2004 | 05:40 PM
Smokin Joe's Avatar
Smokin Joe
changed bulbs today, didn't take five minutes. Took the headlight surround bezel (black plastic) off. If you remove the headlights, even better access.
Old Nov 3, 2004 | 03:26 AM
Navy Blue's Avatar
0Navy Blue
Former Vendor
Does having a Vararam make changing the foglights any more difficult?
Old Nov 3, 2004 | 03:26 PM
Navy Blue's Avatar
0Navy Blue
Former Vendor
Does Vararam make access any harder?
Old Nov 3, 2004 | 10:21 PM
D.K.'s Avatar
D.K.
I changed mine to blue yesterday. It's tight but you can do it. You must take off the black HL bezels, only 3 phillips screws per side.
Old Nov 3, 2004 | 11:01 PM
USA-VET's Avatar
USA-VET
What no pics ET?
Old Nov 4, 2004 | 02:25 AM
USA-VET's Avatar
USA-VET
Originally Posted by USA-VET
What no pics ET?
Old Nov 4, 2004 | 01:17 PM
Evil-Twin's Avatar
Evil-Twin
you want nakkie pictures???
To Replacing fog lights - access
