What is it with...
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
these sensors --- ABS and tracking control? I have had the car to service. The Corvette tech. checked the connections, cleaned them, etc. Everything I have seen in discussions here. But the lights will still come on -- at least once during any one day.
I turn the car off --- and restart as the car manual suggests --- the sensors tend to come back on ---
There doesn't seem to be any rhyme or reason to them coming on.
Has anyone found a solution? I would even be willing to have new sensors installed, it that would solve the problem.
![](/forums/images/ranks/7k-10k.gif)
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I had a short circuit causing power fluctuations and them it turned out that the trolls (GM Service) shorted out my PCM (near the alternator) and that gave me these lights. I would say if it's nothing else, check all your connections (aftermarket stereo, etc.) and them proceed to the PCM etc. Good luck!
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 19,862 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
The possibility of a short could be the cause, but also check the computer (maybe it is acting up). Good luck finding the cause. Electrical problems are a bear to figure out at times.
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
I noticed mine doing this a week or two ago...
...I dont think it is the computer...
I seemed to come on randomly...
...then I noticed that when I hit a bump the lights come on...
I suspect a bad connection...this should be fun to locate...
I will attack the CDchanger first...then ????
