How often do you get it?
Old Oct 26, 2004 | 11:29 PM
Tino's Avatar
Tino
Default How often do you get it?
I knew this would get your attention, your oil changed that is. What did you think I was talking about. I did my first oil change at about 4,200kms and my gauge still said about 65% life still left? How far can you go before you change your oil.
Tino
Old Oct 26, 2004 | 11:32 PM
C5XPert's Avatar
C5XPert
As often as my hand will allow.....
Old Oct 26, 2004 | 11:33 PM
Shortimer's Avatar
Shortimer
Common question here. I change my oil once a year or at the 5K mark, whichever comes first. I do my own oil changes. I ignore the oil life info on the DIC.
Old Oct 26, 2004 | 11:35 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
From what I have read that is a tricky question to answer since there are so many variables that go into the calculation.
Old Oct 26, 2004 | 11:43 PM
Larry_Yerton's Avatar
Larry_Yerton
Somewhere around 40% for me, which is about 7k or twice a year. I also change the filter once in between each oil change.
Old Oct 26, 2004 | 11:45 PM
jrose7004's Avatar
jrose7004
10% on the DIC!
Old Oct 27, 2004 | 06:40 AM
I change mine when the DIC oil life remaining says between 40-45%. That comes to about 4500 miles between changes. The manual says do not go over 10K between changes, but depending on the conditions, it could be even less than 3K between needed changes.
Old Oct 27, 2004 | 07:41 AM
footba4672's Avatar
footba4672
change mine every 4 mos or about 4500 miles
once a year just seems much to long for me....doesnt the oil lose its viscosity over time as well with use
Old Oct 27, 2004 | 10:58 AM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
i change mine every 4k-5k miles. it comes out to be about twice a year. the car has 90k miles and hasn't had a problem with that schedule.
Old Oct 27, 2004 | 11:44 AM
spiral04vette's Avatar
spiral04vette
From: Los Angeles I'm here for a good time, not a long time!
My 04 is my Daily Driver, so I rack up about 80 miles a day on it. I change my oil every 7500 miles regardless of whats on the DIC.
Old Oct 27, 2004 | 12:23 PM
SavPrato's Avatar
SavPrato
Old Oct 27, 2004 | 12:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I usually follow my DIC (sorry, couldn't resist! )When it indicates 30-35% oil life remaining which for me translates to about 4500 miles, I'll get it changed. 4500kM if I did the conversion right is 2790 miles. Personally, I think you're throwing away perfectly good oil at that low mileage.
Old Oct 27, 2004 | 12:45 PM
lager99's Avatar
lager99
St. Jude Donor '06
Considering the computer monitors speed, heat, rpm etc...to determine your oil % how about when it hits close to 0%.
Old Oct 27, 2004 | 08:33 PM
Patman's Avatar
Patman
I went 5000 miles on my last oil change, and the DIC showed 39% oil life. My oil analysis results showed the oil definitely could've gone longer.
Next spring when I get rid of the oil from the winter months (yes I'll be driving it in the snow) I plan on running that oil change interval right to the end of the oil life on the DIC. I'm confident the oil analysis results will show it could go even longer, especially since the 97-00 C5s oil life monitor is calibrated for a 10k maximum while the 01-04 is redone for the 15k maximum that they went with in 2001.
To How often do you get it?
