Looking for a "Build Sheet"
Old Oct 27, 2004 | 11:47 AM
vet_owner_2004's Avatar
vet_owner_2004
3rd Gear
Default Looking for a "Build Sheet"
Looking for a build sheet for the following vet.
VIN #:1G1YY32G345119525
Thanks for the help.
Old Oct 27, 2004 | 11:54 AM
Thunder7's Avatar
Thunder7
You can buy them from the NCM.
https://www.corvettemuseum.com/libra...ts/index.shtml
Old Oct 27, 2004 | 11:55 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
I think that is the only way to get them.
Old Oct 27, 2004 | 11:59 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Supposedly there is a build sheet stuffed into one of the front cross members of the chassis - but without taking the whole car apart, it's near to impossible to remove in one piece.
The museum is certainly the best way!
Old Oct 27, 2004 | 12:08 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE Warranty Start Date : 04/09/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : WALTER EARL CHEVROLET, INC.
PO BOX 609
BRIDGEWATER , MA 02324-0609
(508) 697-6000
VIN 1G1YY32G345119525
VEHICLE BUILD
Gross Vehicle Weight Rating : 1672 kg (3687 lb) Order Number : GQZBVF
Build Date : 01/20/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE F55 - MAGNETIC SELECTIVE RIDE CNTRL
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NE1 - 50-STATE EMISSIONS
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
N73 - CUSTOM SPORT MAGNESIUM WHEELS R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 67I - LIGHT OAK INTERIOR TRIM
67T - T0P-LIGHT OAK 673 - LT OAK SEATING TRIM
86U - PREMIUM COLOR - MAGNETIC RED METALLIC II
Old Oct 27, 2004 | 12:42 PM
Vette-Dream's Avatar
Vette-Dream
Hmm I'm calling beginners luck on ya Sponge Vette
How about trying my C5
1G1YY32G9W5105583
Old Oct 27, 2004 | 01:11 PM
vet_owner_2004
3rd Gear
Old Oct 27, 2004 | 01:43 PM
Check with the NCM. They will sell you one.
Old Oct 27, 2004 | 02:07 PM
Sponge Vette
1G1YY32G9W5105583
You must be new to the Forum. Ok here is your info and for you a little extra.
VEHICLE INFORMATION
Merchandising Model : 1YY67 -1998 CORVETTE CONVERTIBLE Warranty Start Date : 03/05/1998
Delivering Dealer : MEDVED CHEVROLET, INC.
11001 W I-70 FRONTAGE RD N
WHEAT RIDGE , CO 80033-2102
(303) 421-0100
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/11/2004 176755 # V1153 - 04006 - INSTALL HARNESS KIT - AUTOMATICS ONLY 65442 miles
06/27/2001 414476 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 35058 miles
06/27/2001 414476 # T2020 - TOWING 35058 miles
12/20/2000 392683 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 29994 miles
06/13/2000 369370 # J4206 - WIRES AND/OR BOOTS, SPARK PLUG - ONE - REPLACE 25275 miles
06/13/2000 369370 # K5180 - CABLE, SHIFT CONTROL - REPLACE 25275 miles
06/13/2000 369370 # K5225 - CONTROL ASSEMBLY, FLOOR SHIFT - REPLACE 25275 miles
06/13/2000 369370 # T2020 - TOWING 25275 miles
08/14/1999 332128 # N0110 - BATTERY - ONE - REPLACE 18246 miles
07/07/1999 326504 # J4206 - WIRES AND/OR BOOTS, SPARK PLUG - ONE - REPLACE 16738 miles
01/09/1999 303315 # N4921 - MODULE, LOCAL INTERFACE UNIT - DOOR - LEFT - REPLACE 11797 miles
01/09/1999 303315 # N3215 - ACTUATOR ASSEMBLY - DOOR LOCK - LEFT FRONT - REPLACE 11797 miles
09/29/1997 A05583 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY32G9W5105583
VEHICLE BUILD
Gross Vehicle Weight Rating : 1698 kg (3744 lb) Order Number : 9939ZU
Build Date : 09/17/1997 Build Plant : 1W5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY PASSENGER POWER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT LEATHER BUCKET
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
C05 - CONVERTIBLE FOLDING ROOF DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS F45 - CONTINUOUSLY VARIABLE REAL TIME DAMPING
GU2 - REAR AXLE 2.73 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL QD4 - STYLED ALUMINUM WHEEL
UL0 - AM/FM STEREO CASSETTE RADIO UZ6 - QUAD SPEAKER SYSTEM
U1S - COMPACT DISC PLAYER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AY - STOCK ORDERS PROC OPTION
1SB - OPTION PACKAGE - BASE 10U - ARTIC WHITE
16T - TOP-WHITE 94I - FIRETHORN RED
943 - FIRETHORN RED LEATHER
Old Oct 27, 2004 | 02:29 PM
sharpvet03's Avatar
sharpvet03
Its on the front right crossmember,but just about impossibe to get to,go threw the museum..
Old Jan 27, 2018 | 09:53 AM
QRSRacingProducts's Avatar
QRSRacingProducts
1st Gear
Default BUILD SHEET FOR 1998 Convert
Hello all,I am new to the corvette forum.I just purchased a 98 Nassau blue conv, my 1st corvette !I would like to find out more info, would it be possible to do a build sheet on VIN : 1G1YY32G7W5122138Any help would be greatly appreciated, Thanks Rich
Old Jan 27, 2018 | 10:22 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Incorrect. The original is in the front crossmember. Personally I'd much rather have the original then some generic reprinted one.
Incorrect. Simply remove the front bumper and the styrofoam. It would take maybe an hour and it's rolled up and in great shape aside from a layer of dust.
Here's mine. You can see the piece of masking tape the factory used to stick it to the car as it went down the line. My car was further disassembled in this picture because I was doing a major project.
Old Jan 27, 2018 | 11:57 AM
f6john's Avatar
f6john
I agree with Josh. Removing and reinstalling the front bumper cover is not that big of a job. I was removing mine for a respray and snagged mine at that time. Don’t know if I would pull it just for the sheet unless the original was really important.
Old Jan 27, 2018 | 07:42 PM
ttchybrid's Avatar
ttchybrid
How would I get the claim history of my 2004 vette?? Vin# 1G1YY12S145109245
Old Jan 28, 2018 | 07:15 AM
Sids04's Avatar
Sids04
The option codes are on the glovebox door. It pretty much covers what's on the build sheet.
Old Feb 1, 2018 | 11:15 AM
mrmagloo's Avatar
mrmagloo
Here's a site that I stumbled on a while back that will create a pretty good replacement window sticker using the codes from the glovebox sticker:
https://corvetteparts.com/page/sticker
Old Feb 2, 2018 | 08:17 PM
msandym's Avatar
msandym
The convertibles are that much heavier ?
To Looking for a "Build Sheet"
